Linearizing logaritmic pots
it’s possible to linearize some of the analog inputs via software to attach some log pots?
You could map the analog value to a new value, similar to the way how it is done in analog_toolbox. But in general the results won’t be good enough for serious work, because you will miss some values!
i have to  try… if it will offer sufficent precision i’ll be very happy
if not i have to try in analog way  :frowning: :frowning: ???
Selfservice,
I think the hardware idea has come up here before, and the consensus was that it can only work the other way around (lin to log) with resistors. :cry:
Maybe TK or someone would know if you could get a more “software cooperative” version of an audio log pot by adding something. (?)
George
