… well, that’s a point. But can’t you make the meters visible on the left side of each track in your software?
yes and no. you can, but you have to open each track window, which takes up way too much space (i only have a 15" tft), but then even on a 19" you wouldnt be able to fit 16 audio tracks onto the screen. I’ll edit this post with a picture later, but basically it takes up too much screen space to be able to see all the level meters without having the mixer window ontop of the tracks, and having the mixer in the way was what im trying to avoid.
… not with the standard LC-Design (there is a total of max. 128 LEDs)…Â But you could run with two cores per 8 cannels. You build a regular MIDIBox LC and from the MIDI Thru of this core you go to the second core and use this one just for metering LEDs… so you’d have 16 per channel.
hmm, this would probably be the best option, and probably quite easy to make too. I might do this.
… I don’t like the control24 at all… too cheapy, noisy faders
Its a very nice design though, eeaasy to navigate and such. Yeah, the faders did seem a little cheap considering the total price, but the buttons were quite hard and firm, i didnt feel like i was going to break them. Anyway, its a nice design, especially for metering purposes.
The reason i want some form of external metering is so that i can get a good idea of where everything is in the mix without having to open any windows on screen, as i have too little screen space as it is :-. i want to be able to just look down and if something looks too low i can just bring the relevant fader up.
[Edit]
Thats what it looks like with just 3 tracks open :-\ Theres no way i can fit 16 on, hence wanting a meter bridge.
Just out of interest, could i make an independant meter bridge (ie, to be used without the midibox LC), might make one before the LC, just to get a feel for how it all works and such.
Thanks for all the help guys
