The LED functions can be changed in the LED map (I’m not sure how you’ve changed the configuration - if you’ve used the mk_syx.pl script, see the midibox64.ini file)
I just have noticed that the comments in midibox64.ini are wrong. Value 9 displays External Bank 1-8, Value 10 External Bank 9-16
The map is also located in mb64_presets.inc for the case that you want to change the source code directly.
Thanks TK, yep, it really was easy. Now I understand how the LED map works. Never had ocassion to look at it before.
Now I have a really good reason to.
I just bought a PowerCore MkII DSP card and Access Virus synth plugin. Awsome.
There are about 200 paramters to tweak and I have come up with a novel way utilising the MB64 with colour coded banks (coloured LEDs) and coloured printed labels.
