LEDs on/off via MIDI
Hi all,
I need control midibox LEDs from PC via MIDI. I want use the AIN 64 DIN 128 DOUT128(example) program, because I need 128 buttons. But in this example isn’t code to drive switching LEDs via MIDI. The MB64 program is too complicated for me, and I can’t find this problem in large code.
I thing that the place for switching code is at USER_MPROC_NotifyFoundEvent.
Thank you for any reply.
Best Regards, LX.
LX-
I noticed tonight in Serge’s vmidibox editor, you can apparently map d.out lights to whatever MIDI signals you have your d.in buttons set to, so if they see that same message come in, they light up.
It may not be exactly what you’re talking about, but it was easier for me to do than finding it in the code right now, and I’m also just learning the stuff.
                                                            -Take Care
-Jidis
Thank you for reply, but this work in MidiBox64 prog., which can use only 64 Buttons. I need 128 Buttons, it supports AIN 64 DIN 128 DOUT128(example) program, which is for me more simple, but it haven’t part of code for lighting LEDs from incaming MIDI events.
I don’t know how to prog.  :-[
Thnk for help
LX
Hi LX
funny that you just have the same problem as I wanted to post now. I noticed the same effect, compared to the midio128 application where it is possible to trigger the led with midi.
as far as I can see the ain64_din128_dout128_v1_3 - application is only a test application, and will lack the functionalities of midio128 (the amount of code speaks for this).
to get to the required result we either have to expand the midio128 application so that it can handle AIN as well, or if the ain64_din128_dout128 can be expanded so the DOUT reacts on midi-events. Maybe some of the experts can give us a hint or two?
however, I am not familiar with PIC programming or assembler, so for the moment I cant give any help, but we might join forces… :wink:
so long
martin
I would guess the vmidibox result is available through the right changes or includes in the midio source, but it looks like most of us in this thread are on the same level.
:cry:
The MIDIBox skeleton and example apps are the same way, so comparing them with a full featured source would give an idea of what to add. I’m guessing again that most of it isn’t specific to just the MB64 apps.
-George
I could give you a small C function which allows you to control all 128 LEDs, I just need to know which MIDI events should be assigned to the LEDs?
I need “Note” MIDI event  0x90  to the LEDs…
I’m interested, if AIN 64 DIN 128 DOUT128 program in one core is work with MidiBox 64 prog. in second core via MIDIbox Link. Is it able?
Thank you for all …
LX
ok, if you want to use two cores anyhow, the solution is much simpler: just open mios_tables.inc in the AIN64DIN128DOUT128 application and replace 0xb0 (CC) by 0x90 (Note)
Then add following line to USER_Init:
  MIOS_MIDI_MergerSet(MIOS_MIDI_MERGER_MBLINK_FP)
to configure this core as a “forwarding point”
or:
  MIOS_MIDI_MergerSet(MIOS_MIDI_MERGER_MBLINK_EP)
to use it as an “endpoint”
P.S.: don’t forget to clamp all unused analog inputs to ground (for the DIN/DOUT core this means: the whole J5 port)
In order to get my head around the AIN64DIN128DOUT128 application and the mios_tables.inc:
The first 128 entries define the midi-events sent in case of a DIN-event.
The next 64 entries define the midi-events sent in case of a AIN-event.
Where are the events defined that control the 128 DOUT? Do they correspond with the 128 entries for DIN? That would mean If I send back the same midi-event received for a DIN-event, the corresponding DOUT LED will be set on/off, like with MIDIO128, right? (my tests showed this doesnt happen, but maybe I made a mistake?).
When a DIN-event occours, the corresponding DOUT LED lights up. Is it possible to turn this off?
thanks for any hints
martin
Hi Martin,
whoops - you are right. I oversaw that the LEDs are not MIDI controllable in this application.
However, just open main.asm, search for following comment:
        ;; here we could insert code which switches the LEDs on/off via
        ;; MIDI
        return
[/code]
Replace it by:
[code]
USER\_MPROC\_NotifyFoundEvent
 ;; entry number is in WREG --- it corresponds to the LED which should be switched
 ;; the note velocity (or CC value) switches on/off the LED, it's stored in MIOS\_PARAMETER3
        IFSET  MIOS\_PARAMETER3, 6, call MIOS\_DOUT\_PinSet1 ; set LED if value \>= 64
&nbsp; &nbsp; &nbsp; &nbsp; IFCLR&nbsp; MIOS\_PARAMETER3, 6, call MIOS\_DOUT\_PinSet0 ; clear LED if value \< 64
 ;; thats all
&nbsp; &nbsp; &nbsp; &nbsp; return
In order to prevent that a button controls a LED, search for “USER_DIN_NotifyToggle” and remove following code:
        ;; now toggle the appr. DOUT LED
        movf    TMP3, W                        ; button number has been saved in TMP3. This is also
the LED number
        IFCLR  TMP4, 0, call MIOS_DOUT_PinSet1 ; if button has been pressed (value = 0V = CLR): LED
on
        IFSET  TMP4, 0, call MIOS_DOUT_PinSet0 ; if button has been depressed (value = 5V = SET): L
ED off
[/code]
P.S.: sometimes I don't know why I'm writing comments... ;-)
Hi Thorsten
Thank you very much for your quick reply. I successfully implemented the MIDI controllable code for DOUT.
Though deleting the code inside the “USER_DIN_NotifyToggle” function doesnt do the trick. The button still toggles the corresponding LED.
However, when I plug off/on the powersupply to the core, the Button doesnt toggle the LED anymore. Only.. nor can I control the LED via MIDI anymore. The button still sends its MIDI signal though.
As soon as I upload the new main.hex (I work with MIOS studio) I have the same effects again as I described above.
I made the following test:
When I simply delete the code-snipplet inside “USER_DIN_NotifyToggle” without adding the code for “USER_MPROC_NotifyFoundEvent”, it works as expected: The button doesnt toggle the LED anymore (and the LED doesnt react on MIDI signals of course).
…Its still pretty dark in this black box, and I just lost my lighter…anybody got a match?
cheers
martin
P.S.
P.S.: sometimes I don’t know why I’m writing comments… :wink:
…  in order to understand your stroke of genius from last month again! :slight_smile:
Hi Thorsten
Thank u very, very, much…
I was on holliday today and yerserday. When I arrived, I have nice present from you…I have all my problems solved. :smiley:
Thanks
Best Regards
LX
Great! So, only Martin’s issue is still open.
Martin: could it be that there is a syntax error - you can check this in main.err
Important: there must be at least one space character before each instruction, otherwise it will be interpreted as a label
Hi Thorsten
no errors at all.
The only message during build that doesnt look kosher is:
Make: The target “C:/…/ain64_din128_dout128_v1_3/main.o” is out of date.
kind regards
martin
Additional information
There might be an issue with the “USER_MPROC_NotifyFoundEvent” function
playing around with lcd_print I figured out the following:
  • once the application is uploaded and a button is pressed, the function is called, even though NO midisignal was sent to the midibox. (according to the doc it only reacts on received midisignals that are mapped in the CONFIG_MIDI_IN table)
I print out the entrynumber with “call MIOS_LCD_PrintBCD3”. no matter which button is pressed (see above) or which midisignal I send the number is “55” (Assuming this method displays the content of WREG). However, the proper LED is switched on and off - so I obviously dont grasp the whole thing…
  • after a (power off/on)-Mios boot, the USER_MPROC_NotifyFoundEvent is not called anymore (the display doesnt show any reaction), not even by a button.
best regards
martin
Hi martin
>> Make: The target “C:/…/ain64_din128_dout128_v1_3/main.o” is out of date. <<
I solved this message .>> I removed directory /ain64_din128_dout128_v1_3/ to C:\
Your path is mabye too long.
best regards
LX
Thanks LX
but this not the case. I had the mentioned errormessage of a path longer than 62(?I think) charakters and resolved this. As far as I can say, I dont have any problem with the compiler. all is green.
can you control the DOUT’s with midi?
best regards
martin
Hi Martin
Yes, Now I can control the DOUT via MIDI.
When I send Midi event from PC to MidiBox, the LEDs are lighting in agreement with mios_tables.inc.
When a Audio program in PC is more clever, it send back same midi event which receive from MIDIbox…
best regards
LX
by chance are you usings cubase?..
i cant get cubase to echo the midibox commands back, to turn on and off the led’s…
eveything works fine when i use midiox, because it is echoing the input back to the output.
but, in cubase, pushing buttons does nothing to the leds ( but changes the settings in cubase.,
,however using the mouse to chance the parameter that the button controls, correctly changes the leds…
is there a line of code i could add to make the button toggle the led as well as the midi signal?
thanks
shmuu102,
Assuming you’re running a fairly current Cubase and the “generic” remote-
If you pull up the generic editor window where you assign all your controls, in the top (source) columns, each item has flag parameters you can change over on the right. They default to “R” or receive, but you can add the “T” or transmit capability to any of them, and they’ll send their changes back out from Cubase as well. There’s also a “relative” encoder type setting, maybe for jog/shuttles or something.
Don’t feel bad, I’ve been on Nuendo since v.1 and I just figured out it could do that a few weeks ago :-[
-George
