I’m new to the MIDIbox project, so bear with me. The page for the MIDIbox64E makes mention of “LEDrings”… can those be bought pre-assembled or are they just a series of LEDs attached to the panel?
No, they are mot pre-assembled. You have to make them by yourself. A lot of LEDs …
greets
Doc
I thought so. I think I’ll mount the LEDs on a PCB with the ring design. I’m new to this, so I guess I gotta learn to make PCBs… :-/
In his designs Thorsten just glued the LEDs to the frontpanel and wired them up without any PCB. It’s supposed to be a lot easier that way.
I suppose it would be cheaper, but not necessarily easier and certainly not neater.
By the way, what kind of LEDs should I use? I saw these really tiny ones, I think they’re referred to as “low profile LEDs”, but the leads stick out to the side instead of down like most LEDs. I assume they can be bent.
… seems like it is easier ;) You have to remember, that there is also an encoder sitting in the middle of the ring :-/
http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=concepts;action=display;num=1104455259
… yes they can be bent. I bought some of these from “voti”
http://www.voti.nl/shop/p/LED-4.html
Greets, Roger
It depends.. on many factors. d2k used pcb mount leds on his 2 MB_LCs: http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=gallery;action=display;num=1084140820 but also had a professionally made boards and frontpanels.
Now - because the led rings are not only “a series of LEDS”, but matrixed - you’ll need a doublesided board, or you’ll end up having lots of jumpers - and having lots of jumper wires, in my mind, really defeats the advantages of having a pcb done.
What kind of a frontpanel you’re going to have? LEDs clearly sticking out of it, or visible from the holes of the frontpanel?
I mean - You would have to align and solder a number of leds.. to certain height, aligned precisely. And the fun doesn’t stop here - then comes the hard part: attaching and fitting the board to the frontpanel…!!!
Bye, Moebius
I’m not sure yet, but I like the idea of having the LEDs sticking out of the panel just a little.
I downloaded Eagle today and came up with a PCB layout for one LEDring, but something happened and it didn’t get saved… :P Even though a 2-layer solution may be more logical, it looks like the design is possible using a 1-layer board. You’d need a ribbon cable going from the board to a “distributor board”, which in turn is connected to the DOUT module. It maybe a bit too much, but it seems like a more elegant solution to the LEDring problem than just wires soldered to the LEDs glued to the frontpanel.
Well, those tiny LEDs sit flush and flat against the PCB. It means you’d need a PCB *just* for the LEDs, with holes drilled for the encoders which would sit on a bord underneath the LEDring board. That may not be the most economical idea, but I might consider it.
But hey, I’ve seen some excellent designs in here that look great on the outside and are a rat’s nest inside, so who cares? ;) I just have a tendency to be extra picky, so bear with me – I used to go to school for graphic design…
