LED sources - 3mm Bi-Colour???
Hi everybody,
just wondering if anyone has any thoughts where i could find some high-output (200+mcd)bi-colour LEDs.
I’m using pads from <monome.org> which require 3mm (T1) size LEDs. The trick is to have access to 3 different colours for more visual correlation between buttons rather than simply memory.
Example - I want to be able to load a set in ableton and use 3 buttons - 1 for record (Red), Mute (Yellow) and Solo (Green). I’ll program all of the MIDI code in MaxMSP.
I’m happy to spend ~1USD per Dual LED.
If anyone has suggestions, I would be ever-so-grateful.
Trent
.. www.ledtuning.nl
www.ebay.com ..
http://unique-leds.com
