I would like to ask for some clarification on the number of DOUTx4 boards needed for an LC unit. Here is my case. I do not want to have the LED rings or meters but I do want to have the seven segment displays (digits). I have looked at the srio code and it appears the code expects 16 serial registers with registers 0x08-0x0B connected to the led rings and 0x0C-0x0F connected to the digits displays. Since I don’t have the rings are the digits connected to registers 0x08-0x0B and registers 0x0C-0x0F not required to exist?
Thanks for the quick reply. I thought it worked that way but wanted to be sure before I make new PCBs. I am distributing the shift register chips across several PCBs to eliminate the bulk of the cables. There will be no cables for the buttons, encoders and LEDs only the shift register clock, load and data signals will be cables.
