Hi! First post here! Loving the clean interface of this forum. Great people, keep up the good work!
I am thinking of using a 74HC595 as described in the LED rings schematic: 11 LEDs per ring with column drivers, and X number of rings with row current sinks.
I believe each pin is sinking too much current. The Fairchild 74HC595 datasheet says 25mA sink or source under Absolute Maximum, MM74HC595 says ±35mA. Given that every 11th LED is on at once, or only 11 LEDs are on at once, this may not be a problem. But it seems like it is awefully close to the Absolute (read danger) rating.
It would be cool to apply a PWM signal the Output Enable (pin 13) of the 74HC595 to globally adjust brightness of the LEDs. This should work, right?
