I’m wondering, if there is a chance, to add more LEDs to a led-meter. I’m asking because I can’t find any 16-segment-led-meter and would need to build them by myself, which is a lot of work. I found a 20-segment-led-meter.
I don’t want to cut other bargraphs… I want it to look nice and I’m afraid, that this is not a perfect solution. Besides this, if I can get 24 LEDs running I have a higher resolution…
Yes, I could chain two of these. That should work.
Another idea is, to simply add two SR and add eight LEDs, which are assigned to a separate led-pattern. Than I scale the cc-value on the first led-stripe from 0-80 (value need to by correctly calculated) and the second stripe from 81-127.
What I meant was, to chain two led-matrix-pattern. To simplify the case: Is it possible, to set up 2x16 LEDs (=32 LEDs in total) and to program the ngc-file in the way, that the first 16 leds listen to cc (x) and value 0-63, and the second set of leds to cc (x) and value 64-127? With that setup it should be possible, to get a higher resolution on led-feedback or am I wrong?
