Hi
Im currently Testing a 8x16 LED Matrix. I can’t find out why all the rows are lighting up simultaneously.
the .NGC config is a simple test:
RESET_HW
LCD "%C"
LCD "@(1:1:1)OLED1"
# Test D-OUT LEDmatrix board
# Matrix control by a Encoder connected to DIN Board on Pin D0/D1
ENC n=1 sr=1 pins=6:7 type=detented2
DOUT_MATRIX n=1 rows=16 inverted=0 inverted_row=0 sr_dout_sel1=1 sr_dout_r1=2 sr_dout_r2=3
EVENT_ENC id= 1 fwd_id=LED_MATRIX:1 type=CC chn= 1 cc= 24 lcd_pos=1:1:2 label="^std_enc" LED_MATRIX_PATTERN=1
LED_MATRIX_PATTERN n= 1 pos= 0 pattern=0000000000000000
LED_MATRIX_PATTERN n= 1 pos= 1 pattern=1000000000000000
LED_MATRIX_PATTERN n= 1 pos= 2 pattern=1100000000000000
LED_MATRIX_PATTERN n= 1 pos= 3 pattern=1110000000000000
LED_MATRIX_PATTERN n= 1 pos= 4 pattern=1111000000000000
LED_MATRIX_PATTERN n= 1 pos= 5 pattern=1111100000000000
LED_MATRIX_PATTERN n= 1 pos= 6 pattern=1111110000000000
LED_MATRIX_PATTERN n= 1 pos= 7 pattern=1111111000000000
LED_MATRIX_PATTERN n= 1 pos= M pattern=1111111100000000
LED_MATRIX_PATTERN n= 1 pos= 8 pattern=1111111110000000
LED_MATRIX_PATTERN n= 1 pos= 9 pattern=1111111111000000
LED_MATRIX_PATTERN n= 1 pos=10 pattern=1111111111100000
LED_MATRIX_PATTERN n= 1 pos=11 pattern=1111111111110000
LED_MATRIX_PATTERN n= 1 pos=12 pattern=1111111111111000
LED_MATRIX_PATTERN n= 1 pos=13 pattern=1111111111111100
LED_MATRIX_PATTERN n= 1 pos=14 pattern=1111111111111110
LED_MATRIX_PATTERN n= 1 pos=15 pattern=1111111111111111
My diagram of the circuit shows the DOUTs that are connected to LED boards where all the Cathodes are parallel and the Anodes connected directly to the DOUT 2-3 as the example on the top left corner shows.
What am i doing wrong here?
Thanks for some help.
Best Regards
Novski
