LED Matrix around 8 Encoders
I have problems with my LED Matrix.
I built it upon the Schematic of Fairlightiii’s pcb but with just 8 Encoders and LED Rings.
By turning one of the Encoders all LEDs around the other Encoders go on, but the LEDs around the Encoder i turn don’t.
And the brightness of the LEDs increase by Turning all the Encoders to 127.
Don’t know where to start searching.
The PCB is correct, i checked that.
this ist my config .ngc for testing:
RESET_HW
LCD "%C"
LCD "@(1:1:8)OLED1"
LCD "@(2:1:8)OLED2"
LCD "@(3:1:8)OLED3"
LCD "@(4:1:8)OLED4"
LCD "@(5:1:8)OLED5"
LCD "@(6:1:8)OLED6"
LCD "@(7:1:8)OLED7"
LCD "@(8:1:8)OLED8"
# Buttons configuration
EVENT_BUTTON id=1 fwd_id=LED:1 type=NoteOn key=24 lcd_pos=1:1:1 label="^std_btn"
EVENT_BUTTON id=2 fwd_id=LED:2 type=NoteOn key=37 lcd_pos=2:1:1 label="^std_btn"
EVENT_BUTTON id=3 fwd_id=LED:3 type=NoteOn key=38 lcd_pos=3:1:1 label="^std_btn"
EVENT_BUTTON id=4 fwd_id=LED:4 type=NoteOn key=39 lcd_pos=4:1:1 label="^std_btn"
EVENT_BUTTON id=5 fwd_id=LED:5 type=NoteOn key=40 lcd_pos=5:1:1 label="^std_btn"
EVENT_BUTTON id=6 fwd_id=LED:6 type=NoteOn key=41 lcd_pos=6:1:1 label="^std_btn"
EVENT_BUTTON id=7 fwd_id=LED:7 type=NoteOn key=42 lcd_pos=7:1:1 label="^std_btn"
EVENT_BUTTON id=8 fwd_id=LED:8 type=NoteOn key=43 lcd_pos=8:1:1 label="^std_btn"
EVENT_BUTTON id=9 fwd_id=LED:9 type=NoteOn key=36 lcd_pos=1:1:1 label="^std_btn"
EVENT_BUTTON id=10 fwd_id=LED:10 type=NoteOn key=37 lcd_pos=2:1:1 label="^std_btn"
EVENT_BUTTON id=11 fwd_id=LED:11 type=NoteOn key=38 lcd_pos=3:1:1 label="^std_btn"
EVENT_BUTTON id=12 fwd_id=LED:12 type=NoteOn key=39 lcd_pos=4:1:1 label="^std_btn"
EVENT_BUTTON id=13 fwd_id=LED:13 type=NoteOn key=40 lcd_pos=5:1:1 label="^std_btn"
EVENT_BUTTON id=14 fwd_id=LED:14 type=NoteOn key=41 lcd_pos=6:1:1 label="^std_btn"
EVENT_BUTTON id=15 fwd_id=LED:15 type=NoteOn key=42 lcd_pos=7:1:1 label="^std_btn"
EVENT_BUTTON id=16 fwd_id=LED:16 type=NoteOn key=43 lcd_pos=8:1:1 label="^std_btn"
EVENT_BUTTON id=17 fwd_id=LED:17 type=NoteOn key=36 lcd_pos=1:1:1 label="^std_btn"
EVENT_BUTTON id=18 fwd_id=LED:18 type=NoteOn key=37 lcd_pos=2:1:1 label="^std_btn"
EVENT_BUTTON id=19 fwd_id=LED:19 type=NoteOn key=38 lcd_pos=3:1:1 label="^std_btn"
EVENT_BUTTON id=20 fwd_id=LED:20 type=NoteOn key=39 lcd_pos=4:1:1 label="^std_btn"
EVENT_BUTTON id=21 fwd_id=LED:21 type=NoteOn key=40 lcd_pos=5:1:1 label="^std_btn"
EVENT_BUTTON id=22 fwd_id=LED:22 type=NoteOn key=41 lcd_pos=6:1:1 label="^std_btn"
EVENT_BUTTON id=23 fwd_id=LED:23 type=NoteOn key=42 lcd_pos=7:1:1 label="^std_btn"
EVENT_BUTTON id=24 fwd_id=LED:24 type=NoteOn key=42 lcd_pos=8:1:1 label="^std_btn"
EVENT_BUTTON id=41 fwd_id=LED:41 type=NoteOn key=43 lcd_pos=1:1:2 label="^std_btn"
EVENT_BUTTON id=41 fwd_id=LED:25 type=NoteOn key=43 lcd_pos=1:1:2 label="^std_btn"
EVENT_BUTTON id=42 fwd_id=LED:42 type=NoteOn key=36 lcd_pos=2:1:2 label="^std_btn"
EVENT_BUTTON id=43 fwd_id=LED:43 type=NoteOn key=37 lcd_pos=3:1:2 label="^std_btn"
EVENT_BUTTON id=44 fwd_id=LED:44 type=NoteOn key=38 lcd_pos=4:1:2 label="^std_btn"
EVENT_BUTTON id=45 fwd_id=LED:45 type=NoteOn key=39 lcd_pos=5:1:2 label="^std_btn"
EVENT_BUTTON id=46 fwd_id=LED:46 type=NoteOn key=40 lcd_pos=6:1:2 label="^std_btn"
EVENT_BUTTON id=47 fwd_id=LED:47 type=NoteOn key=41 lcd_pos=7:1:2 label="^std_btn"
EVENT_BUTTON id=48 fwd_id=LED:48 type=NoteOn key=42 lcd_pos=8:1:2 label="^std_btn"
# Encoder configuration
ENC n= 1 sr=4 pins=0:1 type=detented2
ENC n= 2 sr=4 pins=2:3 type=detented2
ENC n= 3 sr=4 pins=4:5 type=detented2
ENC n= 4 sr=4 pins=6:7 type=detented2
ENC n= 5 sr=5 pins=0:1 type=detented2
ENC n= 6 sr=5 pins=2:3 type=detented2
ENC n= 7 sr=5 pins=4:5 type=detented2
ENC n= 8 sr=5 pins=6:7 type=detented2
# LEDring configuration
DOUT_MATRIX n= 1 rows=8 sr_dout_sel1= 7 sr_dout_sel2= 0 sr_dout_r1= 8 sr_dout_r2= 9
# Encoder events
EVENT_ENC id= 1 fwd_id=LED_MATRIX:1 type=CC chn= 1 cc= 24 lcd_pos=1:1:4 label="^std_enc"
EVENT_ENC id= 2 fwd_id=LED_MATRIX:2 type=CC chn= 1 cc= 25 lcd_pos=2:1:4 label="^std_enc"
EVENT_ENC id= 3 fwd_id=LED_MATRIX:3 type=CC chn= 1 cc= 26 lcd_pos=3:1:4 label="^std_enc"
EVENT_ENC id= 4 fwd_id=LED_MATRIX:4 type=CC chn= 1 cc= 27 lcd_pos=4:1:4 label="^std_enc"
EVENT_ENC id= 5 fwd_id=LED_MATRIX:5 type=CC chn= 1 cc= 28 lcd_pos=5:1:4 label="^std_enc"
EVENT_ENC id= 6 fwd_id=LED_MATRIX:6 type=CC chn= 1 cc= 29 lcd_pos=6:1:4 label="^std_enc"
EVENT_ENC id= 7 fwd_id=LED_MATRIX:7 type=CC chn= 1 cc= 30 lcd_pos=7:1:4 label="^std_enc"
EVENT_ENC id= 8 fwd_id=LED_MATRIX:8 type=CC chn= 1 cc= 31 lcd_pos=8:1:4 label="^std_enc"
# we've a single MBHP_MF_NG module with 8 motorfaders
# It has to be configured for Motormix protocol!
MF n=1 enabled=1 midi_in_port=IN2 midi_out_port=OUT2 chn=1 ts_first_button_id=2001 config_port=USB3
# on motorfader movements
EVENT_MF id= 1 fwd_id=ENC:33 type=CC chn= 1 cc=32 range=0:127 lcd_pos=1:1:5 label="^std_mf"
EVENT_MF id= 2 fwd_id=ENC:34 type=CC chn= 1 cc=33 range=0:127 lcd_pos=2:1:5 label="^std_mf"
EVENT_MF id= 3 fwd_id=ENC:35 type=CC chn= 1 cc=34 range=0:127 lcd_pos=3:1:5 label="^std_mf"
EVENT_MF id= 4 fwd_id=ENC:36 type=CC chn= 1 cc=35 range=0:127 lcd_pos=4:1:5 label="^std_mf"
EVENT_MF id= 5 fwd_id=ENC:37 type=CC chn= 1 cc=36 range=0:127 lcd_pos=5:1:5 label="^std_mf"
EVENT_MF id= 6 fwd_id=ENC:38 type=CC chn= 1 cc=37 range=0:127 lcd_pos=6:1:5 label="^std_mf"
EVENT_MF id= 7 fwd_id=ENC:39 type=CC chn= 1 cc=38 range=0:127 lcd_pos=7:1:5 label="^std_mf"
EVENT_MF id= 8 fwd_id=ENC:40 type=CC chn= 1 cc=39 range=0:127 lcd_pos=8:1:5 label="^std_mf"
# on touchsensor event (first id has been specified in the MF configuration above)
EVENT_BUTTON id= 2001 type=NoteOn chn= 1 key=0x68 range=0:127 lcd_pos=1:1:6 label="^std_btn"
EVENT_BUTTON id= 2002 type=NoteOn chn= 1 key=0x69 range=0:127 lcd_pos=2:1:6 label="^std_btn"
EVENT_BUTTON id= 2003 type=NoteOn chn= 1 key=0x70 range=0:127 lcd_pos=3:1:6 label="^std_btn"
EVENT_BUTTON id= 2004 type=NoteOn chn= 1 key=0x71 range=0:127 lcd_pos=4:1:6 label="^std_btn"
EVENT_BUTTON id= 2005 type=NoteOn chn= 1 key=0x72 range=0:127 lcd_pos=5:1:6 label="^std_btn"
EVENT_BUTTON id= 2006 type=NoteOn chn= 1 key=0x73 range=0:127 lcd_pos=6:1:6 label="^std_btn"
EVENT_BUTTON id= 2007 type=NoteOn chn= 1 key=0x74 range=0:127 lcd_pos=7:1:6 label="^std_btn"
EVENT_BUTTON id= 2008 type=NoteOn chn= 1 key=0x75 range=0:127 lcd_pos=8:1:6 label="^std_btn"
Any Ideas?
Thanks
novski
Sounds like an inverted selection.
Are you using ULN2803 as sink drivers?
Then you would have to use following configuration:
DOUT_MATRIX n= 1 rows=8 inverted_sel=1 sr_dout_sel1= 7 sr_dout_sel2= 0 sr_dout_r1= 8 sr_dout_r2= 9
Or you are not using an ULN2803, but the polarity of the LEDs is wrong?
Then try:
DOUT_MATRIX n= 1 rows=8 inverted_sel=1 inverted_row=1 sr_dout_sel1= 7 sr_dout_sel2= 0 sr_dout_r1= 8 sr_dout_r2= 9
Hi TK.
Wonderful! it was the Inverter… The Polarity is equal to fairlightiiis pcb.
But i designed just 15 LEDs because for Audio Panorama functionality i want a Middle “single” LED.
Now the Middle point is decreased to left. I expected it to increase to right because the LED missing there. (my LEDs are like fairlightiii’s from left to right) Is that because of the Inverting?
Thanks a lot!
novski
inverting != mirroring
You have to create your own LED_MATRIX_PATTERNs for 15 instead of 11 (or in the lre8x2 setup: 16) LEDs.
Do i understand right?
Mirroring = It lets the LEDs go “ON” in the opposite direction (shift-register Outputs go Low in Opposite direction as without)
Inverting = It swaps the row and selector shift registers
Best Regards
Novski
No, inverting means, that the signals on the DOUT output will be reversed.
Means: instead of 1, a 0 will be output, and instead of 0, a 1 will be output.
This is required for the case that somebody swapped anode/cathode of a LED, or to revert the polarity change of a sink driver.
