Hi…
okay, i tracked down the problem - for some reason the LED for the midi out status will now only work if i bypass the 470ohm resistor, tho very occasionally it’d flicker and/or work a bit when connected as normal after the resistor - weird???
No matter tho, i just have brighter midi out LED is all…
Best
Dan
