In Der Midibox LC läuft das LED Digits.
und im NG Leuchten all als 8+Dot
Confi der NGC
Reset the setup to default settings
This command ensures, that previous hardware definitions will be overwritten
by a new setup without the need to set defintions for all components
RESET_HW**
LCD “%C@(1:1:1 Lc test LED Ring Meter”
SysEx communication
# Device ID selects the device:
# 0x10 : Logic Control
# 0x11 : Logic Control XT
# 0x14 : Mackie Control
# 0x15 : Mackie Control XT
SYSEX_VAR dev=0x14
# Receive Device Query -> send Host Connection Query
EVENT_RECEIVER id= 1 fwd_id=SENDER:1 \
type=SysEx stream=“0xf0 0x00 0x00 0x66 ^dev 0x00 0xf7”
EVENT_SENDER id= 1 \
type=SysEx stream=“0xf0 0x00 0x00 0x66 ^dev 0x01 0x4d 0x42 0x4e 0x47 0x56 0x31 0x00 0x00 0x00 0x00 0xf7”
# Receive Host Connection Reply -> send Host Connection Confirmation
EVENT_RECEIVER id= 2 fwd_id=SENDER:2 \
type=SysEx stream=“0xf0 0x00 0x00 0x66 ^dev 0x02 0xf7”
EVENT_SENDER id= 2 \
type=SysEx stream=“0xf0 0x00 0x00 0x66 ^dev 0x03 0x4d 0x42 0x4e 0x47 0x56 0x31 0xf7”
# Firmware version request
EVENT_RECEIVER id= 3 fwd_id=SENDER:3 \
type=SysEx stream=“0xf0 0x00 0x00 0x66 ^dev 0x13 00 0xf7”
EVENT_SENDER id= 3 \
type=SysEx stream=“0xf0 0x00 0x00 0x66 ^dev 0x14 0x56 0x31 0x2e 0x34 0x32 0xf7”
# Special Query for Mackie Control
EVENT_RECEIVER id= 4 fwd_id=SENDER:4 \
type=SysEx stream=“0xf0 0x00 0x00 0x66 ^dev 0x1a 0xf7”
EVENT_SENDER id= 4 \
type=SysEx stream=“0xf0 0x00 0x00 0x66 ^dev 0x1b 0x42 0xf7”
**# this generic receiver (without controller assignment) receives the MTC digits
and notifies all events which select syxdump_pos=10:<pos-in-dump>**
EVENT_RECEIVER id=10 type=SysEx stream=“0xf0 0x00 0x00 0x66 ^dev 0x10 ^dump”
**# this generic receiver (without controller assignment) receives the status digits
and notifies all events which select syxdump_pos=11:<pos-in-dump>**
EVENT_RECEIVER id=11 type=SysEx stream=“0xf0 0x00 0x00 0x66 ^dev 0x11 ^dump”
**# LCD Messages
Note: we use ^txt56 instead of ^txt, so that the cursor will jump
# to the next line after the 56th character has been reached
# Use map=1 to map the cursor positions over a 2x80 LCD
EVENT_RECEIVER id= 5 \
type=SysEx stream=“0xf0 0x00 0x00 0x66 ^dev 0x12 ^cursor ^txt56” \
range=map1**
**# X cursor positions are defined in MAP1
spread message over two 2x40 LCDs
MAP1 2 3 4 5 6 7 8 \
12 13 14 15 16 17 18 \
22 23 24 25 26 27 28 \
32 33 34 35 36 37 38 \
42 43 44 45 46 47 48 \
52 53 54 55 56 57 58 \
62 63 64 65 66 67 68 \
72 73 74 75 76 77 78**
**# use this definition instead of the one above to print on a GLCD with small font (will work with a 240x64 LCD)
if multiple GLCDs are used, you could also use the normal font (&n)
not shown here: of course, it’s possible to map to different cursor positions as well.
event_receiver id= 5 \
# type=SysEx stream=“0xf0 0x00 0x00 0x66 ^dev 0x12 ^cursor ^txt56” \
# lcd_pos=1:3:1 label=“&s”**
Rec/Ready 1-8 (Note Key: 0x00..0x07)
EVENT_BUTTON id= 1 type=NoteOn chn= 1 key=0x00
EVENT_BUTTON id= 2 type=NoteOn chn= 1 key=0x01
EVENT_BUTTON id= 3 type=NoteOn chn= 1 key=0x02
EVENT_BUTTON id= 4 type=NoteOn chn= 1 key=0x03
EVENT_BUTTON id= 5 type=NoteOn chn= 1 key=0x04
EVENT_BUTTON id= 6 type=NoteOn chn= 1 key=0x05
EVENT_BUTTON id= 7 type=NoteOn chn= 1 key=0x06
EVENT_BUTTON id= 8 type=NoteOn chn= 1 key=0x07**
EVENT_LED id= 1 type=NoteOn chn= 1 key=0x07
EVENT_LED id= 2 type=NoteOn chn= 1 key=0x06
EVENT_LED id= 3 type=NoteOn chn= 1 key=0x05
EVENT_LED id= 4 type=NoteOn chn= 1 key=0x04
EVENT_LED id= 5 type=NoteOn chn= 1 key=0x03
EVENT_LED id= 6 type=NoteOn chn= 1 key=0x02
EVENT_LED id= 7 type=NoteOn chn= 1 key=0x01
EVENT_LED id= 8 type=NoteOn chn= 1 key=0x00
Mute 1-8 (Note Key: 0x10..0x17)
EVENT_BUTTON id= 9 type=NoteOn chn= 1 key=0x10
EVENT_BUTTON id= 10 type=NoteOn chn= 1 key=0x11
EVENT_BUTTON id= 11 type=NoteOn chn= 1 key=0x12
EVENT_BUTTON id= 12 type=NoteOn chn= 1 key=0x13
EVENT_BUTTON id= 13 type=NoteOn chn= 1 key=0x14
EVENT_BUTTON id= 14 type=NoteOn chn= 1 key=0x15
EVENT_BUTTON id= 15 type=NoteOn chn= 1 key=0x16
EVENT_BUTTON id= 16 type=NoteOn chn= 1 key=0x17**
EVENT_LED id= 9 type=NoteOn chn= 1 key=0x17
EVENT_LED id= 10 type=NoteOn chn= 1 key=0x16
EVENT_LED id= 11 type=NoteOn chn= 1 key=0x15
EVENT_LED id= 12 type=NoteOn chn= 1 key=0x14
EVENT_LED id= 13 type=NoteOn chn= 1 key=0x13
EVENT_LED id= 14 type=NoteOn chn= 1 key=0x12
EVENT_LED id= 15 type=NoteOn chn= 1 key=0x11
EVENT_LED id= 16 type=NoteOn chn= 1 key=0x10
Solo 1-8 (Note Key: 0x08..0x0f)
EVENT_BUTTON id= 17 type=NoteOn chn= 1 key=0x08
EVENT_BUTTON id= 18 type=NoteOn chn= 1 key=0x09
EVENT_BUTTON id= 19 type=NoteOn chn= 1 key=0x0a
EVENT_BUTTON id= 20 type=NoteOn chn= 1 key=0x0b
EVENT_BUTTON id= 21 type=NoteOn chn= 1 key=0x0c
EVENT_BUTTON id= 22 type=NoteOn chn= 1 key=0x0d
EVENT_BUTTON id= 23 type=NoteOn chn= 1 key=0x0e
EVENT_BUTTON id= 24 type=NoteOn chn= 1 key=0x0f**
EVENT_LED id= 17 type=NoteOn chn= 1 key=0x0f
EVENT_LED id= 18 type=NoteOn chn= 1 key=0x0e
EVENT_LED id= 19 type=NoteOn chn= 1 key=0x0d
EVENT_LED id= 20 type=NoteOn chn= 1 key=0x0c
EVENT_LED id= 21 type=NoteOn chn= 1 key=0x0b
EVENT_LED id= 22 type=NoteOn chn= 1 key=0x0a
EVENT_LED id= 23 type=NoteOn chn= 1 key=0x09
EVENT_LED id= 24 type=NoteOn chn= 1 key=0x08
Select 1-8 (Note Key: 0x18..0x1f)
EVENT_BUTTON id= 25 type=NoteOn chn= 1 key=0x18
EVENT_BUTTON id= 26 type=NoteOn chn= 1 key=0x19
EVENT_BUTTON id= 27 type=NoteOn chn= 1 key=0x1a
EVENT_BUTTON id= 28 type=NoteOn chn= 1 key=0x1b
EVENT_BUTTON id= 29 type=NoteOn chn= 1 key=0x1c
EVENT_BUTTON id= 30 type=NoteOn chn= 1 key=0x1d
EVENT_BUTTON id= 31 type=NoteOn chn= 1 key=0x1e
EVENT_BUTTON id= 32 type=NoteOn chn= 1 key=0x1f**
EVENT_LED id= 25 type=NoteOn chn= 1 key=0x1f
EVENT_LED id= 26 type=NoteOn chn= 1 key=0x1e
EVENT_LED id= 27 type=NoteOn chn= 1 key=0x1d
EVENT_LED id= 28 type=NoteOn chn= 1 key=0x1c
EVENT_LED id= 29 type=NoteOn chn= 1 key=0x1b
EVENT_LED id= 30 type=NoteOn chn= 1 key=0x1a
EVENT_LED id= 31 type=NoteOn chn= 1 key=0x19
EVENT_LED id= 32 type=NoteOn chn= 1 key=0x18
SRegister 5
EVENT_BUTTON id= 33 type=NoteOn chn= 1 key=0x60
Cursor Up 0x60
EVENT_BUTTON id= 34 type=NoteOn chn= 1 key=0x5d
Stop 0x5d
EVENT_BUTTON id= 35 type=NoteOn chn= 1 key=0x5c
Fast Fwd 0x5c
EVENT_BUTTON id= 36 type=NoteOn chn= 1 key=0x5b
Rewind 0x5b
EVENT_BUTTON id= 37 type=NoteOn chn= 1 key=0x61
Cursor Down 0x61
EVENT_BUTTON id= 38 type=NoteOn chn= 1 key=0x62
Cursor Left 0x62
EVENT_BUTTON id= 39 type=NoteOn chn= 1 key=0x64
Zoom 0x64
EVENT_BUTTON id= 40 type=NoteOn chn= 1 key=0x63
Cursor Right 0x63**
**EVENT_LED id= 33 type=NoteOn chn= 1 key=0x59
Add Marker 0x59
EVENT_LED id= 34 type=NoteOn chn= 1 key=0x5a
Next Marker 0x5a
EVENT_LED id= 35 type=NoteOn chn= 1 key=0x5b
Rewind 0x5b
EVENT_LED id= 36 type=NoteOn chn= 1 key=0x5c
Fast Fwd 0x5c
EVENT_LED id= 37 type=NoteOn chn= 1 key=0x5d
Stop 0x5d
EVENT_LED id= 38 type=NoteOn chn= 1 key=0x5e
Play 0x5e
EVENT_LED id= 39 type=NoteOn chn= 1 key=0x5f
Record 0x5f
EVENT_LED id= 40 type=NoteOn chn= 1 key=0x64
Zoom 0x64**
SRegister 6
EVENT_BUTTON id= 41 type=NoteOn chn= 1 key=0x58
Previous Marker 0x58
EVENT_BUTTON id= 42 type=NoteOn chn= 1 key=0x56
CYCLE 0x56
EVENT_BUTTON id= 43 type=NoteOn chn= 1 key=0x55
Right Marker 0x55
EVENT_BUTTON id= 44 type=NoteOn chn= 1 key=0x54
Left Marker 0x54
EVENT_BUTTON id= 45 type=NoteOn chn= 1 key=0x5f
Record 0x5f
EVENT_BUTTON id= 46 type=NoteOn chn= 1 key=0x5e
Play 0x5e
EVENT_BUTTON id= 47 type=NoteOn chn= 1 key=0x5a
Next Marker 0x5a
EVENT_BUTTON id= 48 type=NoteOn chn= 1 key=0x59
ADD Marker 0x59 **
**#EVENT_LED id= 41 type=NoteOn chn= 1 key=0xff
no LED
EVENT_LED id= 42 type=NoteOn chn= 1 key=0x33
(Chanal Win) 0x33
EVENT_LED id= 43 type=NoteOn chn= 1 key=0x4e
(Mix Win) 0x4e
EVENT_LED id= 44 type=NoteOn chn= 1 key=0x4d
(Projekt fenster ) 0x4d
EVENT_LED id= 45 type=NoteOn chn= 1 key=0x54
Left Marker 0x54
EVENT_LED id= 46 type=NoteOn chn= 1 key=0x55
Right Marker 0x55
EVENT_LED id= 47 type=NoteOn chn= 1 key=0x56
CYCLE 0x56
EVENT_LED id= 48 type=NoteOn chn= 1 key=0x58
Previous Marker 0x58**
SRegister 7
EVENT_BUTTON id= 49 type=NoteOn chn= 1 key=0x33
(Chanal Win) 0x33
EVENT_BUTTON id= 50 type=NoteOn chn= 1 key=0x53
(Shift) 0x53
EVENT_BUTTON id= 51 type=NoteOn chn= 1 key=0x47
(Redo) 0x47
EVENT_BUTTON id= 52 type=NoteOn chn= 1 key=0x46
(Undo) 0x46
EVENT_BUTTON id= 53 type=NoteOn chn= 1 key=0x48
(SAVE) 0x48
EVENT_BUTTON id= 54 type=NoteOn chn= 1 key=0x49
(Revert) 0x49
EVENT_BUTTON id= 55 type=NoteOn chn= 1 key=0x4d
(Projekt fenster) 0x4d
EVENT_BUTTON id= 56 type=NoteOn chn= 1 key=0x4e
(Mix Win) 0x4e **
**#EVENT_LED id= 49 type=NoteOn chn= 1 key=0xff
no LED
EVENT_LED id= 50 type=NoteOn chn= 1 key=0x4b
Write 0x4b
EVENT_LED id= 51 type=NoteOn chn= 1 key=0x4a
Read / off 0x4a
EVENT_LED id= 52 type=NoteOn chn= 1 key=0x47
Redo 0x47
EVENT_LED id= 53 type=NoteOn chn= 1 key=0x46
Undo 0x46
EVENT_LED id= 54 type=NoteOn chn= 1 key=0x48
SAVE 0x48
EVENT_LED id= 55 type=NoteOn chn= 1 key=0x49
Revert 0x49
EVENT_LED id= 56 type=NoteOn chn= 1 key=0x4f
Motor 0x4f**
SRegister 8
EVENT_BUTTON id= 57 type=NoteOn chn= 1 key=0x41
(Fadergroup 4) 0x41
EVENT_BUTTON id= 58 type=NoteOn chn= 1 key=0x40
(Fadergroup 3) 0x40
EVENT_BUTTON id= 59 type=NoteOn chn= 1 key=0x3f
(Fadergroup 2) 0x3f
EVENT_BUTTON id= 60 type=NoteOn chn= 1 key=0x3e
(Fadergroup 1) 0x3e
EVENT_BUTTON id= 61 type=NoteOn chn= 1 key=0x4a
(READ/OFF) 0x4a
EVENT_BUTTON id= 62 type=NoteOn chn= 1 key=0x4b
(WRITE) 0x4b
EVENT_BUTTON id= 63 type=NoteOn chn= 1 key=0x4f
(MotorFader on/off) 0x4f
#event_button id= 64 type=NoteOn chn= 1 key=0x98
(MIDIbox LC specific: 0x98 **
**EVENT_LED id= 57 type=NoteOn chn= 1 key=0x2c
EQ 0x2c
EVENT_LED id= 58 type=NoteOn chn= 1 key=0x51
FX Master 0x51
EVENT_LED id= 59 type=NoteOn chn= 1 key=0x2d
Chn FX Sends 0x2d
EVENT_LED id= 60 type=NoteOn chn= 1 key=0x50
VSTi 0x50
EVENT_LED id= 61 type=NoteOn chn= 1 key=0x2a
Pan 0x2a
EVENT_LED id= 62 type=NoteOn chn= 1 key=0x2b
Chn Inserts 0x2b
EVENT_LED id= 63 type=NoteOn chn= 1 key=0x29
Page Up 0x29
EVENT_LED id= 64 type=NoteOn chn= 1 key=0x28
Page Down 0x28**
SRegister 9
EVENT_BUTTON id= 65 type=NoteOn chn= 1 key=0x39
(F-4) 0x39
EVENT_BUTTON id= 66 type=NoteOn chn= 1 key=0x38
(F-3) 0x38
EVENT_BUTTON id= 67 type=NoteOn chn= 1 key=0x37
(F-2) 0x37
EVENT_BUTTON id= 68 type=NoteOn chn= 1 key=0x36
(F-1) 0x36
EVENT_BUTTON id= 69 type=NoteOn chn= 1 key=0x42
(Fadergroup 5) 0x42
EVENT_BUTTON id= 70 type=NoteOn chn= 1 key=0x43
(Fadergroup 6) 0x43
EVENT_BUTTON id= 71 type=NoteOn chn= 1 key=0x44
(Fadergroup 7) 0x44
EVENT_BUTTON id= 72 type=NoteOn chn= 1 key=0x45
(Fadergroup 8) 0x45 **
**#EVENT_LED id= 65 type=NoteOn chn= 1 key=0xff
(no LED ) 0xff
#EVENT_LED id= 66 type=NoteOn chn= 1 key=0xff
(no LED ) 0xff
#EVENT_LED id= 67 type=NoteOn chn= 1 key=0xff
(no LED ) 0xff
#EVENT_LED id= 68 type=NoteOn chn= 1 key=0xff
(no LED ) 0xff
#EVENT_LED id= 69 type=NoteOn chn= 1 key=0xff
(no LED ) 0xff
#EVENT_LED id= 70 type=NoteOn chn= 1 key=0xff
(no LED ) 0xff
#EVENT_LED id= 71 type=NoteOn chn= 1 key=0xff
(no LED ) 0xff
#EVENT_LED id= 72 type=NoteOn chn= 1 key=0xff
(no LED ) 0xff**
SRegister 10
EVENT_BUTTON id= 73 type=NoteOn chn= 1 key=0x52
(SOLO Defeat) 0x52
EVENT_BUTTON id= 74 type=NoteOn chn= 1 key=0x4c
(Sends) 0x4c
EVENT_BUTTON id= 75 type=NoteOn chn= 1 key=0x65
SCRUB 0x65
#event_button id= 76 type=NoteOn chn= 1 key=0x84
MBLC_DISPLAY_NEXT 0x84
EVENT_BUTTON id= 77 type=NoteOn chn= 1 key=0x3a
# (F-5) 0x3a
EVENT_BUTTON id= 78 type=NoteOn chn= 1 key=0x3b
(F-6) 0x3b
EVENT_BUTTON id= 79 type=NoteOn chn= 1 key=0x3c
(F-7) 0x3c
EVENT_BUTTON id= 80 type=NoteOn chn= 1 key=0x3d
(F-8) 0x3d **
**#EVENT_LED id= 73 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 74 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 75 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 76 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 77 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 78 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 79 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 80 type=NoteOn chn= 1 key=0xff
(no LED)**
SRegister 11
EVENT_BUTTON id= 81 type=NoteOn chn= 1 key=0x2b
(Channel Insets) 0x2b
EVENT_BUTTON id= 82 type=NoteOn chn= 1 key=0x2f
(Bank Right) 0x2f
EVENT_BUTTON id= 83 type=NoteOn chn= 1 key=0x2e
(Bank Left) 0x2e
EVENT_BUTTON id= 84 type=NoteOn chn= 1 key=0x28
(Page Up) 0x28
EVENT_BUTTON id= 85 type=NoteOn chn= 1 key=0x35
(SMPTE_BEATS) 0x35
EVENT_BUTTON id= 86 type=NoteOn chn= 1 key=0x32
(Flip) 0x32
#event_button id= 87 type=NoteOn chn= 1 key=0xa0
(Punch) 0xa0
#event_button id= 88 type=NoteOn chn= 1 key=0xa1
IGNORE 0xa1 **
**#EVENT_LED id= 81 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 82 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 83 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 84 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 85 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 86 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 87 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 88 type=NoteOn chn= 1 key=0xff
(no LED)**
SRegister 12
EVENT_BUTTON id= 89 type=NoteOn chn= 1 key=0x2a
(Pan) 0x2a
EVENT_BUTTON id= 90 type=NoteOn chn= 1 key=0x31
(BANK_CHANNEL_RIGHT ) 0x31
EVENT_BUTTON id= 91 type=NoteOn chn= 1 key=0x30
(BANK_CHANNEL_LEFT) 0x30
EVENT_BUTTON id= 92 type=NoteOn chn= 1 key=0x29
(Page Down) 0x29
EVENT_BUTTON id= 93 type=NoteOn chn= 1 key=0x2d
(Channel FX Sends) 0x2d
EVENT_BUTTON id= 94 type=NoteOn chn= 1 key=0x51
(MASTER FX 0x51
EVENT_BUTTON id= 95 type=NoteOn chn= 1 key=0x2c
(EQ) 0x2c
EVENT_BUTTON id= 96 type=NoteOn chn= 1 key=0x50
(VSTi) 0x50 **
**#EVENT_LED id= 89 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 90 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 91 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 92 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 93 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 94 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 95 type=NoteOn chn= 1 key=0xff
(no LED)
#EVENT_LED id= 96 type=NoteOn chn= 1 key=0xff
(no LED)**
VPots (Encoders with LED rings)
# LED_MATRIX_PATTERNs
LED_MATRIX_PATTERN n= 1 pos= 0 pattern=0000000000000000
LED_MATRIX_PATTERN n= 1 pos= 1 pattern=1000000000000000
LED_MATRIX_PATTERN n= 1 pos= 2 pattern=0100000000000000
LED_MATRIX_PATTERN n= 1 pos= 3 pattern=0010000000000000
LED_MATRIX_PATTERN n= 1 pos= 4 pattern=0001000000000000
LED_MATRIX_PATTERN n= 1 pos= 5 pattern=0000100000000000
LED_MATRIX_PATTERN n= 1 pos= 6 pattern=0000010000000000
LED_MATRIX_PATTERN n= 1 pos= 7 pattern=0000001000000000
LED_MATRIX_PATTERN n= 1 pos= M pattern=0000000100000000
LED_MATRIX_PATTERN n= 1 pos= 8 pattern=0000000100000000
LED_MATRIX_PATTERN n= 1 pos= 9 pattern=0000000010000000
LED_MATRIX_PATTERN n= 1 pos=10 pattern=0000000001000000
LED_MATRIX_PATTERN n= 1 pos=11 pattern=0000000000100000
LED_MATRIX_PATTERN n= 1 pos=12 pattern=0000000000100000
LED_MATRIX_PATTERN n= 1 pos=13 pattern=0000000000100000
LED_MATRIX_PATTERN n= 1 pos=14 pattern=0000000000100000
LED_MATRIX_PATTERN n= 1 pos=15 pattern=0000000000100000
LED_MATRIX_PATTERN n= 2 pos= 0 pattern=0000000000000000
LED_MATRIX_PATTERN n= 2 pos= 1 pattern=1111110000000000
LED_MATRIX_PATTERN n= 2 pos= 2 pattern=0111110000000000
LED_MATRIX_PATTERN n= 2 pos= 3 pattern=0011110000000000
LED_MATRIX_PATTERN n= 2 pos= 4 pattern=0001110000000000
LED_MATRIX_PATTERN n= 2 pos= 5 pattern=0000110000000000
LED_MATRIX_PATTERN n= 2 pos= 6 pattern=0000010000000000
LED_MATRIX_PATTERN n= 2 pos= 7 pattern=0000011000000000
LED_MATRIX_PATTERN n= 2 pos= M pattern=0000011000000000
LED_MATRIX_PATTERN n= 2 pos= 8 pattern=0000011100000000
LED_MATRIX_PATTERN n= 2 pos= 9 pattern=0000011110000000
LED_MATRIX_PATTERN n= 2 pos=10 pattern=0000011111000000
LED_MATRIX_PATTERN n= 2 pos=11 pattern=0000011111100000
LED_MATRIX_PATTERN n= 2 pos=12 pattern=0000011111100000
LED_MATRIX_PATTERN n= 2 pos=13 pattern=0000011111100000
LED_MATRIX_PATTERN n= 2 pos=14 pattern=0000011111100000
LED_MATRIX_PATTERN n= 2 pos=15 pattern=0000011111100000
LED_MATRIX_PATTERN n= 3 pos= 0 pattern=0000000000000000
LED_MATRIX_PATTERN n= 3 pos= 1 pattern=1000000000000000
LED_MATRIX_PATTERN n= 3 pos= 2 pattern=1100000000000000
LED_MATRIX_PATTERN n= 3 pos= 3 pattern=1110000000000000
LED_MATRIX_PATTERN n= 3 pos= 4 pattern=1111000000000000
LED_MATRIX_PATTERN n= 3 pos= 5 pattern=1111100000000000
LED_MATRIX_PATTERN n= 3 pos= 6 pattern=1111110000000000
LED_MATRIX_PATTERN n= 3 pos= 7 pattern=1111111000000000
LED_MATRIX_PATTERN n= 3 pos= M pattern=1111111000000000
LED_MATRIX_PATTERN n= 3 pos= 8 pattern=1111111100000000
LED_MATRIX_PATTERN n= 3 pos= 9 pattern=1111111110000000
LED_MATRIX_PATTERN n= 3 pos=10 pattern=1111111111000000
LED_MATRIX_PATTERN n= 3 pos=11 pattern=1111111111100000
LED_MATRIX_PATTERN n= 3 pos=12 pattern=1111111111100000
LED_MATRIX_PATTERN n= 3 pos=13 pattern=1111111111100000
LED_MATRIX_PATTERN n= 3 pos=14 pattern=1111111111100000
LED_MATRIX_PATTERN n= 3 pos=15 pattern=1111111111100000
LED_MATRIX_PATTERN n= 4 pos= 0 pattern=0000000000000000
LED_MATRIX_PATTERN n= 4 pos= 1 pattern=0000010000000000
LED_MATRIX_PATTERN n= 4 pos= 2 pattern=0000111000000000
LED_MATRIX_PATTERN n= 4 pos= 3 pattern=0001111100000000
LED_MATRIX_PATTERN n= 4 pos= 4 pattern=0011111110000000
LED_MATRIX_PATTERN n= 4 pos= 5 pattern=0111111111000000
LED_MATRIX_PATTERN n= 4 pos= 6 pattern=1111111111100000
LED_MATRIX_PATTERN n= 4 pos= 7 pattern=1111111111100000
LED_MATRIX_PATTERN n= 4 pos= M pattern=1111111111100000
LED_MATRIX_PATTERN n= 4 pos= 8 pattern=1111111111100000
LED_MATRIX_PATTERN n= 4 pos= 9 pattern=1111111111100000
LED_MATRIX_PATTERN n= 4 pos=10 pattern=1111111111100000
LED_MATRIX_PATTERN n= 4 pos=11 pattern=1111111111100000
LED_MATRIX_PATTERN n= 4 pos=12 pattern=1111111111100000
LED_MATRIX_PATTERN n= 4 pos=13 pattern=1111111111100000
LED_MATRIX_PATTERN n= 4 pos=14 pattern=1111111111100000
LED_MATRIX_PATTERN n= 4 pos=15 pattern=1111111111100000
ENC n= 1 sr=13 pins=0:1 type=non_detented
ENC n= 2 sr=13 pins=2:3 type=non_detented
ENC n= 3 sr=13 pins=4:5 type=non_detented
ENC n= 4 sr=13 pins=6:7 type=non_detented
ENC n= 5 sr=14 pins=0:1 type=non_detented
ENC n= 6 sr=14 pins=2:3 type=non_detented
ENC n= 7 sr=14 pins=4:5 type=non_detented
ENC n= 8 sr=14 pins=6:7 type=non_detented
EVENT_ENC id= 1 type=CC chn= 1 cc=0x10 enc_mode=Inc00Speed_Dec40Speed
EVENT_ENC id= 2 type=CC chn= 1 cc=0x11 enc_mode=Inc00Speed_Dec40Speed
EVENT_ENC id= 3 type=CC chn= 1 cc=0x12 enc_mode=Inc00Speed_Dec40Speed
EVENT_ENC id= 4 type=CC chn= 1 cc=0x13 enc_mode=Inc00Speed_Dec40Speed
EVENT_ENC id= 5 type=CC chn= 1 cc=0x14 enc_mode=Inc00Speed_Dec40Speed
EVENT_ENC id= 6 type=CC chn= 1 cc=0x15 enc_mode=Inc00Speed_Dec40Speed
EVENT_ENC id= 7 type=CC chn= 1 cc=0x16 enc_mode=Inc00Speed_Dec40Speed
EVENT_ENC id= 8 type=CC chn= 1 cc=0x17 enc_mode=Inc00Speed_Dec40Speed
Jogwheel (Encoder)
# Jogwheel
ENC n= 9 sr= 15 pins=0:1 type=non_detented
EVENT_ENC id= 9 type=CC chn= 1 cc=0x3c enc_mode=Inc00Speed_Dec40Speed
DOUT_MATRIX n= 1 rows=16 inverted=0 sr_dout_sel1= 10 sr_dout_r1=11 sr_dout_r2=12
EVENT_LED_MATRIX id= 1 type=CC chn= 1 cc=0x30 led_matrix_pattern=LcAuto
EVENT_LED_MATRIX id= 2 type=CC chn= 1 cc=0x31 led_matrix_pattern=LcAuto
EVENT_LED_MATRIX id= 3 type=CC chn= 1 cc=0x32 led_matrix_pattern=LcAuto
EVENT_LED_MATRIX id= 4 type=CC chn= 1 cc=0x33 led_matrix_pattern=LcAuto
EVENT_LED_MATRIX id= 5 type=CC chn= 1 cc=0x34 led_matrix_pattern=LcAuto
EVENT_LED_MATRIX id= 6 type=CC chn= 1 cc=0x35 led_matrix_pattern=LcAuto
EVENT_LED_MATRIX id= 7 type=CC chn= 1 cc=0x36 led_matrix_pattern=LcAuto
EVENT_LED_MATRIX id= 8 type=CC chn= 1 cc=0x37 led_matrix_pattern=LcAuto
Meters
Assign to lc_meter_port=USB1 (incoming Channel Pressure events will be
converted into meter pattern)
DOUT_MATRIX n= 4 rows=16 inverted=0 sr_dout_sel1=14 sr_dout_r1=15 sr_dout_r2=16 \
lc_meter_port=USB1**
LC_METER_PATTERN pos= 0 pattern=0000000000000000
LC_METER_PATTERN pos= 1 pattern=1000000000000000
LC_METER_PATTERN pos= 2 pattern=1100000000000000
LC_METER_PATTERN pos= 3 pattern=1110000000000000
LC_METER_PATTERN pos= 4 pattern=1110000000000000
LC_METER_PATTERN pos= 5 pattern=1111000000000000
LC_METER_PATTERN pos= 6 pattern=1111100000000000
LC_METER_PATTERN pos= 7 pattern=1111110000000000
LC_METER_PATTERN pos= 8 pattern=1111111000000000
LC_METER_PATTERN pos= 9 pattern=1111111100000000
LC_METER_PATTERN pos=10 pattern=1111111100000000
LC_METER_PATTERN pos=11 pattern=1111111110000000
LC_METER_PATTERN pos=12 pattern=1111111110000000
LC_METER_PATTERN pos=13 pattern=1111111111000000
LC_METER_PATTERN pos=14 pattern=1111111111000000
LC_METER_PATTERN pos=15 pattern=1111111111100000
# where is the overload LED located?
#LC_METER_PATTERN pos= O pattern=0000000000010000
# Reset all meters if the “global meter mode” message is received
EVENT_RECEIVER id= 20 fwd_id=SENDER:20 \
type=SysEx stream=“0xf0 0x00 0x00 0x66 ^dev 0x21”
EVENT_SENDER id= 20 \
type=Meta meta=ResetMeters
Motorfaders
**# we’ve a single MBHP_MF_NG module with 8 motorfaders
It has to be configured for Motormix protocol!
MF n=1 enabled=1 midi_in_port=IN3 midi_out_port=OUT3 chn=1 ts_first_button_id=2001 config_port=USB3**
# on motorfader movements
EVENT_MF id= 1 type=PitchBend chn= 1 range=0:16383
EVENT_MF id= 2 type=PitchBend chn= 2 range=0:16383
EVENT_MF id= 3 type=PitchBend chn= 3 range=0:16383
EVENT_MF id= 4 type=PitchBend chn= 4 range=0:16383
EVENT_MF id= 5 type=PitchBend chn= 5 range=0:16383
EVENT_MF id= 6 type=PitchBend chn= 6 range=0:16383
EVENT_MF id= 7 type=PitchBend chn= 7 range=0:16383
EVENT_MF id= 8 type=PitchBend chn= 8 range=0:16383
# on touchsensor event (first id has been specified in the MF configuration above)
EVENT_BUTTON id= 2001 type=NoteOn chn= 1 key=0x68 range=0:127
EVENT_BUTTON id= 2002 type=NoteOn chn= 1 key=0x69 range=0:127
EVENT_BUTTON id= 2003 type=NoteOn chn= 1 key=0x70 range=0:127
EVENT_BUTTON id= 2004 type=NoteOn chn= 1 key=0x71 range=0:127
EVENT_BUTTON id= 2005 type=NoteOn chn= 1 key=0x72 range=0:127
EVENT_BUTTON id= 2006 type=NoteOn chn= 1 key=0x73 range=0:127
EVENT_BUTTON id= 2007 type=NoteOn chn= 1 key=0x74 range=0:127
EVENT_BUTTON id= 2008 type=NoteOn chn= 1 key=0x75 range=0:127
MTC and Status LED Digits
**# HW definitions for “Common Cathode” Digits
see also http://www.ucapps.de/midibox_ng/mbng_led_digits_mtc.pdf
DOUT_MATRIX n=2 rows=8 sr_dout_r1=17 inverted_row=0 mirrored_row=1 sr_dout_sel1=18 inverted_sel=0
DOUT_MATRIX n=3 rows=8 sr_dout_r2=19 inverted_row=0 mirrored_row=1 sr_dout_sel2=20 inverted_sel=0**
**# for “Common Anode” set inverted_row=1 and inverted_sel=1
if the segment connections are mirrored, set mirrored_row=1**
# the digits are accessible with:
second matrix (n=2): LED_MATRIX:17 … LED_MATRIX:24
third matrix (n=3): LED_MATRIX:33 … LED_MATRIX:40
# direct access to the digits via CC#64..CC#73
EVENT_LED_MATRIX id=33 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 64 syxdump_pos=10:0
EVENT_LED_MATRIX id=34 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 65 syxdump_pos=10:1
EVENT_LED_MATRIX id=17 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 66 syxdump_pos=10:2
EVENT_LED_MATRIX id=18 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 67 syxdump_pos=10:3
EVENT_LED_MATRIX id=19 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 68 syxdump_pos=10:4
EVENT_LED_MATRIX id=20 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 69 syxdump_pos=10:5
EVENT_LED_MATRIX id=21 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 70 syxdump_pos=10:6
EVENT_LED_MATRIX id=22 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 71 syxdump_pos=10:7
EVENT_LED_MATRIX id=23 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 72 syxdump_pos=10:8
EVENT_LED_MATRIX id=24 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 73 syxdump_pos=10:9
# status digits
EVENT_LED_MATRIX id=39 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 75 syxdump_pos=11:1
EVENT_LED_MATRIX id=40 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 74 syxdump_pos=11:0
