Say I got bi colored LED buttons for Live 6, one color to specify a row, lets say horizontal rows will be blue, and when i trigger a sequence with the button, is it possible to have the LED for that button turn the other color? That way I will know what sequences are running..
Is this within the capabilities of the Dout board? or would it require custom programming.. ?
thanxs..
I think it’s possible, if you trigger the button, that the DOUT switches. Or perhaps some hardware config, but that could be tricky if you have a lot of led’s.
Hmm roughly a 5x5 grid.
The problem is, each vertical column can only play one clip at a time. the MIDIBox would have to know that the column is a group, and that only one “active” light can be on at a time.
The way it works is when a clip (sequence) is triggered in that column, the current one stops playing at the end of its sequence and the new one starts. So the light would have to jump to the button that was just pressed.
