I’ve bought this lcd display
it’s hd61202 based
the seller gave me a datasheet (see the attach)
I’m not so good with electronics (and with english also…sob)
Can someone explain me connections?
thanks
it’s hd61202 based
thanks
Hi wonder,
If you are not so experienced then I would highly recommend using a display which is MIOS compatible. You may need to write a new driver for this device.
Edit: No you won’t have to write a new driver, that device is supported. I obviously didn’t read the page well enough! I thought it was a CLCD :![]()
but, don’t the chip hd61202 assure the compatibility?
can anyone help me? sob…
http://ucapps.de/mbhp_lcd.html has instructions for wiring a hd61202 based display
Can you be more specific to what is you are confused of? Is it about the diagram that you provided or the connection instruction from the LCD_Module page?
i’m trying to match info from my diagram and info from connection instruction from the LCD_Module page.
For example…i suppose that the en signal in my diagram is the enable (marked as E http://www.ucapps.de/mbhp/mbhp_glcd0.pdf, I suppose), but what is D/I signal in my diagram? R/S? I don’t know…etcetc
