LCD Question
Hello,
I want to build a MidiboxFM Synth. And want to use 2 20 x 2 LCDs instead of 1 40x4. Is it possible?
I found this one @ farnell and want to use it. Datasheet
Best Regards
Philipp
Yes, it’s possible, but will require some additional coding (in asm) to adjust the LCD driver.
Hello Nils,
thanks for reply! …some additional coding… sounds difficult to me.
I hope someone will help me with the program :slight_smile:
Do you have a wiring diagram , how to connect the LCDs?
Best Regards
Philipp
Here is the wiring diagram for connecting 2 x CLCD’s to a CORE8: mbhp_2xclcd_mios8.pdf
Cheers
Phil
Thanks alot, very helpful :slight_smile:
Cheers
Philipp
