I also have a 16x2 lcd that works when connected, however when I connect the 40x2 displays nothing will show up. Could this be due to the displays requiring a negative 0.3V on V0, as described in the tianma module. Or do these displays need negative contrast voltage?
I see the black line when I connect my 16x2 ( which I thought stopped working but then realized I broke the Enable line), however when I connect either 40x2 I see nothing. I was able to find this datasheet on the Wintek LCD http://www.cyfronika.com.pl/dokumentacje/wmc4002.pdf however I see nothing about needing a negative contrast voltage. The data sheets say VDD-V0 for both should be 4.5V. With VDD at 5V that would mean V0~0.5V . I just don’t want to destroy the module with a negative contrast voltage ( or anything else for that matter).
Thanks for reading the datasheet Lall, however I can’t see any reason why the 40x2 displays won’t work they can’t both be dead (or can they?). And yes my core is working fine, I can get the 16x2 to work fine. I will try testing everything out when I get the chance perhaps I swapped some cabling somewhere. If anyone else has any ideas, let me know. By the way, would placing a negative contrast voltage on the LCD damage the controller at all, were these controllers designed to handle it?
