LCD on midibox SID
hi.
im on half way building my first midibox SID!! i have uploaded MIOS and got sound out of the unit, so im thrilled.
today i implemented the LCDisplay. i got messages: on start up-> n letter and then after acouple of seconds a message: 2 b … b   .
… so i quess its not working right
do i have to upload some other software for the LCD to work?
i checked the cabling couple of times and it seemed to be ok. im using a 20x2 character display(w/backlight) from MIKEs midishop(DEM 20231 SYH-PY / V 442)
please help me out on this.
ami
PS. GREAT PROJECT.. THANKS!
:smiley: :smiley: :smiley: :stuck_out_tongue: :stuck_out_tongue:
Do you have a datasheet for that display? This sounds like you have made a mistake in the wiring - swapped some datalines.
Bye, Moebius
p.s. amppari sounds like Finnish to me..  :wink:
is it the bootstrap thing?
If not, check at least twice if everything is wired correctly, trust me. I rewired my parallel port 2x40 LCD at least 5 times before getting something that works. One time, I even got burnt by the controller ICs because some pins were connected wrong. You would not want to let your expansive LCD dying.
Hi!
Ask Mike for the datasheet (he´s really ok)… or search at google,… I had a display from Mike (2x20)
and found the datasheet easily with google in the www…
Good luck!!
pwx :wink:
i’m working with a same LCD module and used the Displaytech 2x20 datasheet that mike sent.
now here’s what the LCD displays when booting the system:
MEOS 1.4z (this for maybe 2 seconds)
then for REALLY short time there flashes something like
MEHEbootSEH Z1;a (this might be not correct due to the time that the message is shown)
then it goes to
A 1 1  C1 - - -
and stays there. sound can be heard ok. but if i change the preset with Jsynth, the screen stays always the same. is this because i don’t have any buttons or encoders connected to core yet? should the LCD act or response to changes? or is there somethig still wrong? the LCD is lit too…
cheers!!
(finnish first!) :slight_smile:
The MBSID should show the patch name at the second line, this name should be updated whenever you send a new patch with JSynthLib.
But the “wrong character” problem is very new to me - it also seems that characters are missing (but this could be a sideeffect) - not sure if this effect can happen if datalines are swapped
hmm, but is there something wrong with the cable connections rather than in the LCD compatibility? i’m not quite sure what to do next…  ???
Hi!
Check your hardware again ???
Best,
pwx ::slight_smile:
Check is one wire is not broken. Should you have just one poorly connected and you will get strange results(Wrong wire at the wrong place too). I already got chinese characters on my parallel port LCD because one wire broke.
