Hey again!,
Could anyone here *very briefly* describe the purpose of the different LCD settings? I’ve been stuck mixing the past few nights, but when I left off, I had gotten so frustrated trying to get different display sizes or layouts, that I jumped it and moved to the buttons & lights, figuring I’d get back to it later.
From what I remember, the only thing I really got was the first offset parameter. I did figure out a “centered” 2x16 display on a 2x40, and also some sort of dual display with four different lines of stuff in two 2x16 combos on the 2x40, like if you flipped to the next display mode and it showed up on the right. I also got “8” different knob value parameters across the screen simultaneously, but they went from channels 1-4 and then jumped way up to 20 or 30 something.
The 2nd, 3rd, and 4th parameters were confusing. The decimal from hex equivalents didn’t usually come out to any multiples of the display width, even though they were. (guessing that’s not what they mean)
And before I waste too much learning time, how many of the following “desired functions” are impossible with a standard MB64 app:
Obviously, the full width (non-centered) 2x40 mode
The spacing of 4 (or more) named pot or button values across a 2x40 to align with the physical layout (like the LC)
A way to flip or scroll from the display of one pot’s parameter page to the next, without actually touching that particular control.
 For instance, if you wanted to check Nuendo’s settings for your channel parameters or cue mix remotely, in snap mode, without
 the risk of changing them. Ideally, non-consecutive controls, like if a musician wanted to see what his levels were for the 12th-16th
 knobs, and had a button at that knob group to jump there from the first few knobs, and maybe go knob to knob with additional
 button hits. (probably asking too much)
- Thanks again, and sorry for the long post. Just trying to get in all the details.
                                     - George
PS- If the above is spread over more than a couple of the included MB64 project files, which ones should I focus on?  Â
 Â
