use the 10k ohm (this is 10 000 ohms) where as 1 meg ohm is equal to 1 000 000 ohms. It’s a very good idea to get use to these prefixes as the world of electronics is full of them. Here is a table of how it works.
Perfix
M (Mega) =1 000 000
k (kilo) = 1 000
m (milli) = 0.001
u (micro) = 0.000.001
n (nano) = 0.000 000 001
p (pico) = 0.000 000 000 001
i.e 10k ohms = 10 x 1000 =10 000
10M ohm = 1 x1 000 000 = 1 000 000
The bridge recitfier rated at 600v@1.5A will be fine, remember that only 9V-12V is going in to the midibox and 1.5Amps is a pretty large current, therefore it is unlikely your midibox will draw the amount of current.
Caps ( capacitor or condenser, they are the same thing) don’t have wattage rarings because they don’t consmue real power. The important spec is the voltage rating (as well as the value of capacitane, in Farads). 16V is a conservitive value, but should be considered as minium.
Look around is other stores, someone is bound to have one. Remeber allways to buy at least one more than you need.
