LCD & Bank Stick
hello,
I try to connect a bank stick to IIC-port and a
character LCD to J15. When the Bankstick is not
connected, everything runs fine, if the stick
is connected, the LCD won’t work anymore,
but the application is running normal.
I did not yet check if Bankstick reads/writes work.
Is it a problem to have a bankstick and character LCD
connected at the same time?
PIN 28 of  the PIC is used for both IIC and LCD port.
What is its function?
thanks, this
http://www.midibox.org/dokuwiki/mios_pin_list
The pin is shared but that’s OK :slight_smile:
I wonder if this is related to your other issue…http://www.midibox.org/forum/index.php/topic,12379.0/topicseen.html#msg103103
hmm… I think no. I just disconnected the SRIO boards, the problem
stays. the DOUT-issue is not a malfunction in this way, it’s just kind
of confusing..
the test app works as expected, only the MSB/LSB of
the DOUT-registers are swapped. the single registers appear in the
right order.. and with the ribbon cable wiring you have very few
pontential wiring bug sources :slight_smile:
I’ll check the Bankstick wiring, maybe some solder-bridge or something
(as I already had on a core PCB this mornig..)
some more pics..
problem solved…
me idiot made a shortcut with the mounting screws for the
little bankstick-bord..
but the DOUT-issue still remains.
It already has been answered here:
http://www.midibox.org/forum/index.php/topic,12379.msg103109.html#msg103109
For your own comfort: don’t start double posts!
