lcd 4bits
hello everybody,
i’ve got some lcd (with ks0066 chipset)
How can i adapt this on mios because they are 4 bits models.
Thanks
Does anybody know an elegant way to do this?
MIOS supports 4bit LCD mode on HD44780 controllers, and KS0066 seems to be compatible.
To set data communication in 4 bit mode, you have to override settings made by MIOS_LCD_TypeAutoSet function at startup. This can be done by MIOS_LCD_TypeSet function, read MIOS functions page:
http://www.ucapps.de/mios_fun.html
My uneducated guess:
Appending (quoting MIOS function reference):
       movlw        0x37 | 0x80        ; E1: D.7, 4bit interface
       movwf        MIOS_PARAMETER1
       movlw        0x24 | 0x80        ; E2: C.4, 4bit interface
       movwf        MIOS_PARAMETER2
       movlw        0x00                ; LCD type 0
       call        MIOS_LCD_TypeSet
In main.asm of the application, in “USER_Init” section ,will do :wink:
Bye, Moebius
p.s. Be sure to check MIOS function reference for minor hardware changes needed! :wink:
When you get your LCD up and running, you should try the LCD Benchmark application and post your findings. I am interested in what the results are for a 4 bit mode.
