LC with 17 Encoders
I had this idea when I realised that the Panasonic motorfaders are useless in the LC emulation(not touch sensitive).
So i though that instead of the motorfaders to have another 8 encoders that means 17 in total.
My querry is firstly are there 8 available spare connectors for the encoders and last does that need changes in the code?
Thanx
Check under Midibox LC/Design
There is a .pdf with the connections for encoders. The top picture only shows the (1) dinx4 board. You can hook 4 of them up, so yes you can use 17 encoders.
As for programming, you will have to set up your miditables correctly, that I know. There will be a little bit of setup, but nothing should be too complicated.
… ever thought of building something like this with encoder and LED bar underneath the belt?
http://www.pennyandgiles.com/docGallery/85.PDF
You could take a crawler of RC tanks for the belt or rubber touth belt
http://www1.ch2.conrad.com/xl/2000_2999/2200/2280/2282/228292_BB_00_FB.EPS.jpg
or mold one out of silicone.
I once tried (about 10 or 15 years ago) one of those p&g at a music fair… they don’t feel too bad… better than rotary encoders.
Greets, Roger
