LC problem
hello, i’m a young french guy trying to resolve some problems with my MB and i don’t find the solutions on the site so i’m asking for your help
excuse me for my poor english
I try to build a LC XT but my faders(non motorized) are not recognized and my switchs sometimes send a lot of mute/solo information and just next, the mb doesnt work anymore
for the switchs I have thought first that it was a soldering problem but they work great with the MB64 application so I don’t understand
for the faders i have searched into the LC application any informations about non motorized faders but i didn’t find anything
Finally i have a 2*16 LCD and i don’t know if it’s possible to use it with a LC XT because it doesn’t show the all parameters
thanks for your help
Check that the pinout confuguration in the application code is the same as your soldering. How many DIN boards have you got connected? If you are not using the full set of pushbutton switches you will need to do some custom allocations in the code. “the mb dosent work anymore”… Sorry, not sure what that is… maybe bad soldering causing a short when you press one of the buttons?
Your non- motorised faders should work fine… just use the LC XT in the ‘silent’ mode… (setting within logic)
the 2*16 will work but will not be able to tell you anything!
I would explain further but I really need to sleep now.
thank you Steven C
i’m going to try this
i also want to control logic without the LC mode, just in generic mode but i don’t really know anything about the logic’s environnement
so if you can give me some information about that it will be great
have good night and i hope you can help me
bye
I haven’t used the environment for more than a year, so I forget! But I think there are sample environments for download from the ucapps site somewhere? Maybe it was on the MB64 page…
Try this: http://www.ucapps.de/midibox/midibox_logic_environment.zip
It’s from the MB64 page and there is a cubase setup too.
i have already try it but it doesn’t work very fine
HELLO
i tried to find the “silent mode” in logic audio but i didn’t
if anyone knows where it is, it will be great
Go to the environment settings for the control surfaces, I think, find the LC icon, click on it, and settings come up in the panel on the left, find the fader mode selection, and highlight current setting, and set it to silent.
