Hi seppo and stryd,
Well I have been working on MBFM on and off for a couple of years now
[in fact i just checked through the forum and my first message re: MBFM is from 2005, yikes!] I’m in no way criticising the original OPL3 board layout, just exploring ways of finishing this project before 2010
Anyway, a brief recap: my YMF and YAC chips are from the first bulk order. I have the original OPL3 board hooked up to a V2 core. My PSU is an AC wallwart hooked up to the appropriate caps and regulators mounted on veroboard. I can upload apps to the core fine, so I’m sure MIDI is working fine. The core has the latest version of MIOS and MBFM. Running the MBFM interconnect test app, I’m sure that the core is sending the appropriate signals to the OPL3 board.
The problem is that when running the MBFM firmware I get absolutely no sound from the OPL3 board. Simple as that. The LED on the OPL3 board comes on, there’s + and -12V at the power input on the OPL3 board. I’ve tried two batches of TL074s (hadn’t realised they could be sensitive to static the first time I built the OPL3!). Still nothing.
My current crystal oscillators both seem to be from NOS, I’ve not got a scope so I can’t think of a way to test they are actually working. Any suggestions how to rule this out?
Unfortunately I can’t find the appropriate crystal oscillator here in Prague, so I’m contemplating building the oscillator adapter from gyorgy’s page:
http://web.t-online.hu/gyurek/midibox.htm#oscillator
Anyone explored this option?
My current OPL3 board is from Mike, so there’s no solder screen and some of the tracks are really close together. Although I’ve been over the board with a magnifying glass and scraped every single possible solder bridge, still not a single sound. I’m currently considering either ordering a new OPL3 board from Smash with solder screen to see if that makes a difference, or trying the alternative layout I originally mentioned. The reason for this is that the tracks seems to be more spaced out and therefore less chance of bridges… what do you guys think?
One thing that I did do when testing was to measure the voltages at the YMF chip and YAC chips. Obviously I was very careful, but is there any chance these could get killed by static?
Well, as you can see, now I’m pretty stuck. So any suggestions more than welcomed
TIA
Dave
