have connected cs1 to j28-sda, cs2 to j28-sc and reset to +5v. have uploaded the ks0108-test from mios32_test/app_lcd. after rebooting the lpc the led on the board fades twices and then it just flashes. the lcd itself shows only random rubbish. first on the right side and then on the left. no data at all and no changes within the “rubbish” either. the testlcdpin command from the bootloader works fine! all pins are connected right. the only thing i noticed is that the voltage is about 3.1v instead of 3.3v on the control pins. the data lines work with 5v as expected.
where could be the problem ? have used the display on a pic32 before and it worked fine. dont know how i get this to run on the lpc17. any help appreciated…
nice to know that the flashing is normal. unfortunately i have no access to level-shifters like u mentioned. maybe i can figure something out with an uln2803…
have tried both ks0108-lcd-type (0x81/0x82). no success. i think u r right with the 3.5v. but i have used the display before on a pic32, running @3.3v! worked fine there.
will meassure the voltage on the pic32 tomorrow again to confirm if thats the issue…
thx.
…just tried lcd_type 0x82 (GLCD_KS0108_INVCS) and the on-board-led does not flash! i wonder why that is…
…same “rubbish” on both screen-halves. the only difference is that the led stopped flashing.
cs cant be @5v according to the datasheet. it needs to toggle with the r/w change. will give up for today. i try the level-shifter somehow tomorrow and let u know how it looks like. thanks a lot so far!
CS doesn’t need to be toggled, the datasheet only shows a simple access example.
So: I bet that one or more connections are wrong, especially because KS0108 type displays are usually very easy to handle (there are no error prone configuration sequences).
good news! after reading your answer i measured the pins with testlcdpin again and voila had a short between the enable pin and db1. working fine now! cs1 & cs2 still need to be swapped for some reason, but apart from that im happy! can now start adding a few more interfaces (midi/i2c) and than i will dive into mios32 programming…
…have swapped cs1&cs2 and attached a photo of my lpc17-core. just for completing the topic. and yes, i know there is not even a voltage regulator! its my very first prototype. it has only two modified j15-connectors for two ks0108-displays. 5v are from usb and 3.3v are from the lpc-link-board. have received my 3.3v-regulators and will add them to the board. i2c and midi as well later…
