I would like to build it into a bigger box with keys - Korg MS20 style. Has anyone build something similar? Can any of you midiboxers recommend a simple midikeyboard that is easy to modify so that it would fit into such a build?
I’ve built my own midi-keyboard using an ATMega uC and two 74HC138N. You can get Fatar keyboards without electronics at Doepfer’s webshop, which can be connected to my board. It works very well, it’s velocity sensitive and you can even programm your own velocity curves. If you’re able to burn avr-chips, I could send you some shematics and the sourcecode.
Alternatively you can get the matching electronics at Doepfers shop too, but the price is incredibly high (IMHO). The Keys are about 80€, the electronics are about the same price if you by them. Well, I’m not quite shure about the prices anymore, but it’s something like that.
Bääääär
Hey Bääääär. Thanks! Ill check out Doepfer and contact you when i’m further in the build.
Unfortunately i’m not able to burn chips So I will propably go with the complete Doepfer solution.
