Hey TK and all…
This was an interesting quote that I thought I might break out into a separate topic from the MB303 thread in Design Concepts…
It shouldn’t be so complicated to add a K2A (Key-to-AOUT) option as well (ca. 10 lines of code). It could also forward the gate, e.g. of the first oscillator, and the glide flag. The only reason why I haven’t added this yet is, that I want to collect the requirements before adding such a feature. This should ensure that the implementation is universal enough… however, your requirements are still more simple than expected. Any other functions required?
TK, this is exciting news to me. As I have mentioned elsewhere, I have dreams of not only turning SID V2 into a controller for a modular synth, but also for a dedicated dual oscillator moog-based synth with patch memories (using all of the LFO and EG facilities of the SID - the arpeggiator etc. are exciting possibilities as well!) - essentially like a Moog Source…
In terms of the features for Key to AOUT… Realizing some are less doable than others (or simply NOT doable! ;-P)
The glide flag for sure… This is more of an issue internal to the SID software itself, as the issue is how the EGs react?
Portamento - would be nice if this could be integrated into the KeyCV signal as well, borrowing from the values stored in the SID patch.
Multiple AOUTs (or simply an input into the Matrix) - So far, I can see driving a couple of oscillators, maybe three, and it would be nice to feed each separately (ie. pitch derived from their own CV output - to which KeyCV with or without portamento, pitch bend etc. can then be applied).
Transpose - Again, from the SID patch data - for driving and storing separate oscillator info, a transpose function would be nice - allows you to use the straight AOUT knobs more as a fine tune? This may not be necessary depending on how many steps are in the AOUT knob functions - you just need to be able to dial up with sufficient accuracy…
It might even be easier to interpolate the Transpose / Fine data from the SID oscillator data to AOUTs 1 and 2, and possibly 3 where a third oscillator is used? Maybe 3 and 4 are realized by flags for voice control - OSC1 to AOUT1, OSC2 to AOUT, OSC3 to AOUT3 and just turn on how many you need? Only one external oscillator, just use one…
Just some thoughts, of course… Much of the above may be far more detailed than TK wants to get into with the SID software… ![]()
Gavin.
