I meant the configuration of the midimessages of the midibox..
…thought i had to sysex the .ini files (converted) (found under mk_sysex link on the site) to the PIC…or am i wrong???..
But with this last version i read that i it wasn’t necessary anymore…(or am I wrong now?)…
and…because i read it is also possible to configure this with the vmidibox. (but i still have to sysex it???)
got a little lost through all of this…
And if i connect the midiox and have burned the midibox_plus_v1910_16pots.hex-file on the pic, what should appear on the LC Display? Now there are only black blocks, but the LCD is getting backlight.
ok, it seems that you’ve mixed the MIOS upload procedure with the configuration of a PIC16F based firmware. One reason again to discontinue the old stuff, it produces too much confusion and “communication effort”. :-/
On a PIC16F firmware the black bar should disappear immediately after power-on (note for MIOS users: it disappears during the boot phase, ca. 2 seconds after power-on)
If the bar is still there, your display is not connected correctly or your PIC is not running. Is there any sign of life from your PIC (MIDI messages on pot moves?)
No messages at all, not on the screen (midiox), nothing on the LCD,
checked my lines with the pcb-layout, and everything seem to be okay…stuffed the capactors in the right way and also the 6N138, also no slack joints of solder…but probably…
… your right that my PiC is not working although it get 5Volt on the suggested Pins.
So changed the oscilator (20 Mhz) and gonna test again…
This “working” problem i got before with some core’s but was also able to re-run and resolder everything…so i have good hope…
