here is the code :
#include "cmios.h"
#include "pic18f452.h"
// absolute values are stored in this array
unsigned char enc_value[16];
// This function is called by MIOS after startup to initialize the
// application
void Init(void) __wparam
unsigned char i;
// set shift register update frequency
MIOS_SRIO_UpdateFrqSet(1); // ms
// we need to set at least one IO shift register pair
MIOS_SRIO_NumberSet(16); // for 128 pins
// set speed mode for 16 encoders
for(i=0; i<16; ++i) {
// available speed modes: SLOW, NORMAL and FAST
MIOS_ENC_SpeedSet(i, MIOS_ENC_SPEED_SLOW, 2); // encoder, speed mode, divider
// This function is called by MIOS in the mainloop when nothing else is to do
void Tick(void) __wparam
// This function is periodically called by MIOS. The frequency has to be
// initialized with MIOS_Timer_Set
void Timer(void) __wparam
// This function is called by MIOS when the display content should be
// initialized. Thats the case during startup and after a temporary message
// has been printed on the screen
void DISPLAY_Init(void) __wparam
MIOS_LCD_Clear();
MIOS_LCD_CursorSet(0x00);
MIOS_LCD_PrintCString("Hello World!");
// This function is called in the mainloop when no temporary message is shown
// on screen. Print the realtime messages here
void DISPLAY_Tick(void) __wparam
// This function is called by MIOS when a complete MIDI event has been received
void MPROC_NotifyReceivedEvnt(unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam
// This function is called by MIOS when a MIDI event has been received
// which has been specified in the MIOS_MPROC_EVENT_TABLE
void MPROC_NotifyFoundEvent(unsigned entry, unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam
// This function is called by MIOS when a MIDI event has not been completly
// received within 2 seconds
void MPROC_NotifyTimeout(void) __wparam
// This function is called by MIOS when a MIDI byte has been received
void MPROC_NotifyReceivedByte(unsigned char byte) __wparam
// This function is called by MIOS before the shift register are loaded
void SR_Service_Prepare(void) __wparam
// This function is called by MIOS after the shift register have been loaded
void SR_Service_Finish(void) __wparam
// This function is called by MIOS when an button has been toggled
// pin_value is 1 when button released, and 0 when button pressed
void DIN_NotifyToggle(unsigned char pin, unsigned char pin_value) __wparam
// This function is called by MIOS when an encoder has been moved
// incrementer is positive when encoder has been turned clockwise, else
// it is negative
void ENC_NotifyChange(unsigned char encoder, char incrementer) __wparam
unsigned char new_value;
// do nothing if encoder number greater than array size
if( encoder >= sizeof(enc_value) )
return;
// add incrementer to absolute value, store result in new_value
new_value = enc_value[encoder] + incrementer;
// branch depending on direction
if( incrementer >= 0 ) {
// overrun check: if new value >= 0x80, force to 0x7f (127)
if( new_value >= 0x80 )
new_value = 0x7f;
} else {
// underrun check: if new value >= 0x80, force to 0x00 (0)
new_value = 0x00;
// store and send absolute value if it has been changed
if( new_value != enc_value[encoder] ) {
enc_value[encoder] = new_value;
MIOS_MIDI_TxBufferPut(0xb0); // CC at MIDI Channel #1
MIOS_MIDI_TxBufferPut(0x10 + encoder); // CC# is 0x10 (16) for first encoder
MIOS_MIDI_TxBufferPut(new_value);
// This function is called by MIOS when a pot has been moved
void AIN_NotifyChange(unsigned char pin, unsigned int pin_value) __wparam
and i modified the mios.table.inc as this : extract
;; encoder entry structure
ENC_ENTRY MACRO sr, din_0, mode
dw (mode << 8) | (din_0 + 8*(sr-1))
ENDM
ENC_EOT MACRO
dw 0xffff
ENDM
global _MIOS_ENC_PIN_TABLE
_MIOS_ENC_PIN_TABLE
MIOS_ENC_PIN_TABLE
;; SR Pin Mode
ENC_ENTRY 1, 0, MIOS_ENC_MODE_DETENTED2 ; V-Pot 1
ENC_ENTRY 1, 2, MIOS_ENC_MODE_DETENTED2 ; V-Pot 2
ENC_ENTRY 1, 4, MIOS_ENC_MODE_DETENTED2 ; V-Pot 3
ENC_ENTRY 1, 6, MIOS_ENC_MODE_DETENTED2 ; V-Pot 4
ENC_ENTRY 2, 0, MIOS_ENC_MODE_DETENTED2 ; V-Pot 5
ENC_ENTRY 2, 2, MIOS_ENC_MODE_DETENTED2 ; V-Pot 6
ENC_ENTRY 2, 4, MIOS_ENC_MODE_DETENTED2 ; V-Pot 7
ENC_ENTRY 2, 6, MIOS_ENC_MODE_DETENTED2 ; V-Pot 8
ENC_ENTRY 3, 0, MIOS_ENC_MODE_DETENTED2 ; V-Pot 9
ENC_ENTRY 3, 2, MIOS_ENC_MODE_DETENTED2 ; V-Pot 10
ENC_ENTRY 3, 4, MIOS_ENC_MODE_DETENTED2 ; V-Pot 11
ENC_ENTRY 3, 6, MIOS_ENC_MODE_DETENTED2 ; V-Pot 12
ENC_ENTRY 4, 0, MIOS_ENC_MODE_DETENTED2 ; V-Pot 13
ENC_ENTRY 4, 2, MIOS_ENC_MODE_DETENTED2 ; V-Pot 14
ENC_ENTRY 4, 4, MIOS_ENC_MODE_DETENTED2 ; V-Pot 15
ENC_ENTRY 4, 6, MIOS_ENC_MODE_DETENTED2 ; V-Pot 16
;; encoders 17-32
ENC_EOT
ENC_EOT
ENC_EOT
and it doesn’t work for encoder 9 to 16 !
why ??
