Album by rmouneyres
All constructions related with Midibox projects
01 soudure mainboard
laying out part ready to solder :
here the core module
also there is one AIN module
02 assemblage boitier 01
after soldering the two pcb, wiring everything inside
02 assemblage boitier 02
another view of the inside finished
I haven’t populated all the sockets on the core module as i don’t need them. But the LCD was used for testing so its related components are here
02 assemblage boitier 03
global view, just before closing the case
you can notice the old aluminium plate i’m using. The 10 faders come from a cannibalized equaliser unused for many years… it now comes back to life midiifed
03 boitier1 fini 01
closed box with colours /public/style_emoticons/default/smile.gif" alt=“smile.gif”>
for decoration, I used printable stickers, and then covered with transparent adhesive for long term protection.
03 boitier1 fini 02
backside of the box, you can notice there is only one midi (out) connector.
The box is powered with +5V DC from a GM5 circuit powered via USB…
03 boitier1 fini 03
top view, finished, and working !
01 061220121074
button board using MEC 3F switches
01 061220121075
01 061220121076
a nice tip to fix the pcb without holes and screws : super glue !
01 061220121077
01 071220121078
metal work
01 071220121079
metal work
01 071220121080
adding LCD and cable to the button board
01 071220121081
metal work
01 071220121082
metal work
01 071220121083
metal work
01 071220121084
metal work finished !
01 071220121085
test footswitches integration
01 081220121086
01 081220121090
first try… working… but buttons not in good order.. software hacked
01 091220121091
metal painting
01 091220121092
metal painting
01 091220121093
metal painting
02 13122008
metal painting
02 13122008001
rear sticker
02 13122008002
top sticker
02 13122008003
top vinyl stickers
02 13122008004
lacquer
02 13122008005
something missing… the relay board and the rear jacks
02 13122008006
the top looks finished isn’t it ?
02 13122008007
02 13122008008
the rear too
02 13122008009
the total is awesome
02 13122008010
waiting for the relay board, the jacks are mounted
02 13122008011
and the software is debugged
02 14122008013
view of the DOUT modules with shunted resistors to drive the relays board
03 301220121108
the relay board has arrived and has been soldered !
03 301220121109
03 311220121110
the relay board is finished !
03 311220121111
03 311220121112
03 311220121113
the relay board is mounted !
03 311220121114
the relay board is connected !
04 311220121116
this is a real situation test…or a real mess
05 311220121118
finished midibox guitar fx pedal looper switcher
05 311220121120
05 311220121121
05 311220121122
05 311220121123
05 311220121124
05 311220121125
05 311220121126
05 311220121127
