am trying to program my PIC with the JDM, I can’t get the MCLR value to read more than 12.8V. I have tried adjusting the delay to 1, but it doesn’t seem to have an effect on programming.
Do I need to use “direct mode” instead of “API mode” ?
is the windows2000 driver for the ic-prog required for windows XP?
yes, Windows XP requires the win2000 driver as far as I know, otherwise the access to the serial interface is too slow, so that the C-charging unit of JDM (than faster the pulse, than higher the voltage) cannot be “pumped” to the required voltage levels.
with IC prog 1.05 havent changed any settings and it works fine?
Dont know about using any other drivers? Just the standard IC prog seems to work just fine? for me anyhow, BTW my voltages are not quite as they should be but it burns fine every time?
It does sound like some peeps have had a few prob’s with win2000/NT so as a last resort Win98/ME could be an option.
