The LCD connected to my MB 6582 used to work fine. Today it started showing just boxes or lines. I completely rewired it, and now the backlight doesn’t work, and jiggling wires doesn’t really change it. When I plug my other LCD screen into the MB6582, it works fine.
How fragile are these? This is the second or third LCD screen that’s done this to me. I’ve accidentally plugged them in backwards before, but that doesn’t seem to be the cause. Besides that, I’ve just been doing normal plugging and unplugging for testing purposes.
Hi - I always make sure I’m earthed when I handle any electro-static sensitive devices. Electro-static damage may not always be imediately evident, so a device could fail earlier than it’s mean time to failure data would suggest. An earthing strap is inexpensive but I reckon it’s invaluable.
I think I’ve decided that instead of using a 16 pin IDC connector for the LCD, I’d much rather just manually make an 8 pin, a 6 pin and a 2 pin, and connect it that way. I did that with my latest LCD and it’S working wonderfully.
