Heres an interesting bit of synth history, the roland d-550 - their first digital synth i believe; which was built on the principal of digital emulation of analog synthesis oscillators + filters & envelopes ..with the addition of a wave engine which played rom stored short snippets of sampled audio to give an initial realistic attack portion (or crude audio loop) over layered ontop of a more conventional virtual ‘analog’ patch.
also this synth features eq, chorus & reverb (and others i may forget) ..everything done in the digital domain to make it at all affordable for the era ![]()
its far from perfect, which is what makes it particularly interesting, full of noise, aliasing artifacts and its very rough round the edges.
it maybe possible to tune out some of the less desirable artifacts if one cared to do so; by piggybacking on a more refined DAC section (anyone up for making a parallel to serial converter with afew stock logic ic’s ?
); and the existing one could be improved a little if you really wanted to start messing with its original design.
the DAC section consists of a mono 16 bit DAC (pcm54hp), which works on a parallel interface ! ..and stereo output is achieved through toggling the output between left and right channel with a 4066 silicon switch. this switching mechanism in particular i feel could be improved & maybe the most significant acheleies heel in introducing the least desirable of the artifacts present ![]()
TOP RIGHT:
32.768 XTAL
ROLAND (CUSTOM) - R15229851 / MB87136A / 8735 E83
ROLAND (CUSTOM) - 532000P-7474
ROLAND (CUSTOM) - 532000P-7473
RIGHT-LOWER:
12MHZ XTAL
ROLAND (CUSTOM) - R15229849 / HG61H25B18F / 7K2
HITACHI - HM6264ASP-15
HITACHI - HM62256LP-10
ROLAND (CUSTOM) - R15229848 / D65005G062
NEC - D78312G 022 / 8739PX700
TOP-LEFT:
ROLAND (CUSTOM) - R15229842 / MB87137 / 001 / 8743 E47
ROLAND (CUSTOM) - R15229866 / MB87126A / 006 / 8743 Z81
? - MB81416-10
OUTPUT:
C4570HA
M5216L
LEFT-LOWER:
BURR BROWN - PCM54HP
? - D4066 (4066 ANALOG SWITCH)
OPAMPS - 5238 ? & 4570
DAC section.
