It’s based on two 8580, compatible to the Core32 board and the drivers found in the repository.
Chip select is on J5A, but can be anywhere else.
It only needs a +5V supply, the 9V are generated on board. Also there are output amplifiers
to attennuate the signals to a 1Vpp level, line-out compatible.
The board is 80x50mm, two layer.
I am currently doing a redesign with two 6581 and two 8580 SIDs. More details soon.
Questions, Ideas etc. are welcome.
Hi, luke
In the your MBHP_SID_V4.pdf file the 74HC595 SRs outs are connected to diferent pins of Sids, than I can saw in the Sid module and in the fnp-sid ( stereo sid ) schems. The first SR in this chain controls a data bus instead of addreses and the second SR controls a address bus instead of data.
Is that realy workable without any software changes?
