Info on AIN - DIN module
:frowning:  I’m a real n00b, sorry for this, i’m starting studing electronic cause i want to build a customizable midibox. My problem is that:
Is the Analog IN Module for faders and pots?
Is the Digital IN Module for buttons?
Someone could explain very well the differences?
I know are noob questions but i didn’t find an answer, also where to post them… thanks for your patience.
Gord The Rogue
Yeah, you see that right: AIN for pots/faders (analog voltage range 0 - 5 Volt) and DIN for buttons (input: 0 Volt or 5 Volt).
You should be able to get the most by reading stuff on www.ucapps.de, everything´s excellent documentated.
Greetz!
