Iāve just discovered midibox & am planning to build a controller for DJing.
Welcome aboard dude. What software will you be controlling?
I do a lot of scratching & dont want to replace the fader every few months.
If you really do a lot of scratching I think youād be used to that by now!
I was wondering if anyone has integrated one into their controller yet.
Nope
Any info on how to do so would be much appreciated.
Youāll need to write a serial buss driver for it. Itās SPI-like from the massive 2 seconds I looked at it.
But what is it really what makes a quality linear fader get worn out? - Is it the taper? No, itās the slider part. The slider does not work smooth anymore and gives the user a ābad feelā.
I donāt agree on this front⦠I think thatās maybe true on a mixing desk, but when it comes to turntablism the audio goes to @$^& a long time before the feel of the fader⦠Although often you get a ācrunchy spotā where you can feel the damage that makes the fader noisey/leaky/drop out. Itās meost often due to corrosion and the big one is dust/grit. Tiny bits of dirt get in there and because the fader is moving fast, they punch holes in things when they hit.
But exactly this part will be worn out with Infinium faders too. And I still didnāt see the 1024 step resolution type around yet. The available type has a resolution of only 128 steps.
I dunno⦠Because thereās no electronics near the slider rods you could keep them really heavily lubed up. The 256 step version is out, but the 1024 one is still a rumour for now.
Iām not shure about the wearing out of the taper in DJ use, since the fader gets used much more often and heavyer than in a conventional downmix situation.
Most turntablists use the upfaders almost as much as the xfaders⦠Which always makes me wonder why ppl only talk about fast xfaders around here!
On any mixer I have ever used, it is the taper that has worn out, resulting in the sound bleeding through.
Usually thatās the wiper (that contacts the taper) getting bent up and contacting two points on the taper at once.
Sometimes only lasting a matter of a week or two before this happens.
Thatās a crap fader. Iāve seen turntablists absolutely abuse new faders for a few weeks solid with no rest and they were only just starting to go funkyā¦
can you or anyone shed some light on alps faders lastablility?
Not really. This question is often asked and never answered. Iām sure you will hear a few "I use this one and itās quite good but (Iāve never had any others to compare it to) / (Iāve only compared it with this one other model..) and a few āthis one has good specsā (infinium)
Someone needs to be a pioneer and do some research, talk to numark and technics and such, find out what they use, what their tech is, spend on an infinium or two to test it out, do homework on lubrication and cleaning/foreign object protection, try it with different DJās to get different styles on it, put it all together, and become āthat guy who busted his chops for months and finally found us the best DIY DJ faderā
Until then itās voodoo
If you decide to be that guy, just remember that DJ audio mixer faders are log curve, not linear, so they arenāt usable in a midibox. Or maybe you want to pioneer a log - linear conversion circuit, so peeps can just drop in their favourite mixer fader ā¦
I bet youāre wishing you didnāt ask right now huh
