So here i am:
this project started a couple of years ago, had a first stage as you can see here:
http://www.io-sound.org/MIDI_devices/MIDI_devices.html
then moved on and kept me busy all this last summer long with learning what LC is, how to draw in a vectorial program, how to match that with Eagle s PCBs, etc etc. It was fun!
THIS PROJECT WOULD NOT BE POSSIBLE WITHOUT THE HELP OF A BUNCH OF MIDIBOXers OUT THERE: YOU KNOW WHO YOU ARE !
THANKS THORSTEN, YOUR WORK AND DEDICATION HERE IS LIKE A SUNNY ISLAND IN THE MIDDLE OF A STORMY ELECTRONIC OCEAN! RESPECT!
That was the due blablablaing.This is the actual state:(see 1st picture)
It s an “hybrid” MBLC+MB64E, they will be connected to a MidiSport 2x2 (internally) and ATM it is planned to be connected only via USB.
Joysticks (with pushbuttons), 4x4 pot matrix, X-fader and the first row of encoders are connected to the MB64E.
The 2 GLCDs (128x64), the second row of encoders, 8x2 and 5x2 SparkFun rubber buttons (still missing in the picture), 4 faders (no motorfaders) , navigation switches and teh jog wheel are connected to the MBLC.
All the control surface PCBs have been etched by myself while the COREs, DINs etc come directly from Smashtv s shop, that is offering (if you don t know that already) very high quality stuff for a bargain price.
All the Control Surface modules will be attached to the upper side of the blue acrylic panel, the COREs,DINs,MidiSport, etc. will be connected in the bottom side of the same panel, i ve placed hole so that the pin headers of the CS PCBs can be reached from the bottom side (see 2nd picture).
The balck panel is the front panel (powder coated alu) and the white panel is meant to reinforce the front panel and carry the 5 M5 screws that are connecting the middle(white)/front(black) panels to the blue panel.Got it?
Casing will be a custom made flight case (spare parts from Adam Hall), it s going tobe a bit heavy but that s what i wanted.
There are still a few things i need to fix (especially in the code) but i ll take that later onand i will keep this thread uptodate with pictures and infos.
Now back to work!
Simone
