I’m in the middle of an MIDIBox project and it came to my mind that I could use a I2S compatible audio DAC (TI PCM1754 or PCM1781). I have been reading about the I2S synth on SVN repositories and have some questions:
- Is it possible to make this pinning:
- LRCIN (WS) -> PA15 (J3:TDI)
- BCKIN (CK) -> PB3 (J3:TDO)
- DIN (SD) -> PB5 (J19:SO)
- SCKI (MCLK) -> PC6 (J15B:E) or PC7 (J15A:E)
If yes, how should the MIOS32_SRIO_SPI (in the mios32_config.h) be defined since neither SPI0 (J16) and SPI1 (J8) are used?
- Is it possible to use the DAC to make an audio output for headphones (i.e. while using Traktor)?
Best regards
