Okay, seriously I thought that I was asking some pretty informed questions. If they’re too dumb than I apologize, but I’ve really gone through all the SEQ posts (even tried linking to some to show that).
From your postings it’s difficult for me to find out, which ones of the previous questions are already answered.
Is the DUO-LED setup just onboard DINs and DOUTs?
First of all I want to highlight, that the DUO-LED solution was intended as some nice fun for myself, I never thought that anybody else really wants to spend the same soldering effort (it took some days).
After I got unexpected requests from users, who wanted to build the same (unbelievable in my eyes ;-)) I created this schematic in the hope, that somebody else creates a PCB layout to simplify the construction.
And this is the current state - informations are published, I’ve stopped my own activities in this area in the hope that somebody else continues with this extension, and writes a proper documentation
In saying that then why does there not seem to be any capacitors in either the DIN or DOUT chip?
I soldered the caps at the bottom side of my breadboards
They are very important because of the high power consumption of the LEDs. At least 10 uF should be added in addition to the 100 nF for each 74HC595
Is there just resistors for the DOUT in this (as there is usually resistors for DIN)? Because it looks like the 10k DIN resistors aren’t included.
As you can see in this picture: http://www.midibox.org/midibox_seq_blm_ext/07.jpg, the 10k resistors for the 74HC165 can be seen at the top left corner. There are 16 x 150 Ohm resistors for two 74HC595, and the third 74HC595 has no additional resistor, as this one is not required (LEDs are connected from one DOUT pin to another DOUT pin, and they are not between DOUT and ground) - an additional resistor at the third 74HC595 would only limit the voltage.
I’m really having trouble as the resistors appear to have been taken for granted (and also modified).
I think the best solution would be, if somebody would create a PCB layout for the whole circuit.
P.S.: I got my Duo-LEDs from Reichelt: LED 5 RG-3
