I have a question...
Hello,
I’m mudo and it’s my first post.
My question is: How can I convert my mixer crossfader (mono) in a stereo one. I need that the crossfader be the same. It’s possible??
thanks
Mudo
Nobody has the answer or nobody understood the question???
:-X
Can you say more about this … ?
I’m not sure to understand what you asked …
You might want to ask the question in Design Concepts with a better explanation of what you are trying to accomplish.  MIDIfication is mostly people who are connecting on/off switches to MIDIfy keyboards and organ consoles.  There is not as much experience with continuous controllers like faders here as in other areas of the forum.
Hello guys and sorry for the wait…
My inet connection was broken…
I would to know how to transform one mixer fader in one midi fader. what is/are the diagram/components that I need?
Sorry about my poor english.
Thanks a lot!!!
The faders normally used in the midibox are 10k ohm faders. There are ways to utilize other rated faders, and I believe there are other posts in the forum about them. You could just use a core and an AIN module and setup the fader for a midi controller..
This setup is only for midi use (not audio/midi fader), although you could probably find a way using motorized faders. I am not shure what problems you would run into tapping the fader for the AIN and running audio through however.
-Hope this helps some
