18V DC (2 * 9V batteries with or without rectifier)
15V..20V AC
the psu you got gives DC; but the voltage between the two poles u used isn’t 15 or 18 but 24! so first get your voltages right (why not use 2 batteries) then you can see if it still works
Basically you are trying to ground the -12V line of the P1 PSU with the other PC’s ground. Don’t do this, and don’t try to remove the ground from the PSU, it will become dangerous.
Instead, use batteries for this - they have a ‘floating’ ground so what you are trying to do (use only the voltage difference but not the absolute voltage value) will actually work.
You might also check any existing universal 1.5-12V Power Supplies and measure the Voltage with a Multimeter. I found more than one that has about 15V while it should actually have 12V.
(I always measure before connecting anything, 'cause I don’t trust the printed statement)
I got problems using two (fresh) 9V-batteries; never reached the required 15 Volts ???
However, I burned very smoothly with these “factory-pimped” psu’s ;D
And the right power is elementary as you see. A “burned” PC costs you hundrets of bucks and a “burned ToS” costs your life… don’t spare at the wrong end!
@stryd_one: What do you mean after the recitifier? Like, to bypass it?
I wasnt lefting the recitifier out, it was connected to ~ pins
Well you’d have 12 + 12 = 24, as was said to you, you said it was 22.5, I’m guessing that is because there is a voltage drop across the diodes in the rectifier, and you have taken the measurement from the circuitry after the rectifier.
Oh, no, It’s just that not every PC PSU outputs the Voltage as declared, this one had 22,5 on the connector wich means that the actual output vas +11.25/-11.25 instead of 12.
