Hi
Sorry for this another newbie question(s). But after long time trying to solve this issue i need a little help.
I bought a Picburner (aka JDM) very cheap (same cost of the PIC18F452..lol) that works in a serial port (RS232 - 9 PINs). Well, i need to test it and of course, burn the bootstrap loader on a PIC18F452-IP. I’ll talk what i did and further my questions. Any help is welcome.
I have a PC running with Win Vista Starter (Please, no jokes from you guys..it was free). Can be this OS a problem to use a JDM or burn a PIC? Anyone here already tried to use a JDM and burned a 18F in this OS?
I tried to check the JDM and I tried identify the 18F at this apps : PicPgm, WinPic800, IC-prog. Only in the PicPgm my JDM was recognized, but it not identify the 18F, also i did the MCLR/vpp test and the LED on JDM works (in all apps that I told this test is running). How I can get a feedback for the other tests such as data in/out, etc? Again, I think, this problem can be because I’m under Win Vista?
Another thought, I built my own serial cable, Linking the 2 db9 connectors with these PINs. 2(RD), 3(TD),4(DTR), 5(GND), 7(RTS), 8(CTS). Using only these PINs is enough to send/transmit data for a JDM burn the bootstrap or I need link all the PINs on db9 PINs?
Bellow, some voltages values I has got in the PINS (I has the same values of measuring directly on the PINS of the serial port of my PC).
2(RD)=0.16V
3(TD)= -11v
4(DTR)= -11V
7(RTS)= -11v
8(CTS)= 0.16V
These voltages are enough to put my JDM to work and burn a PIC?
My last question, How I can test my JDM, measuring voltages on it? Any usually tips/advices and clarifications for this measurement? (sorry, no schematics, only a poor quality picture, if anyone want)
I already thank for any clarification, tip or advice.
