Hi, I want to make a CV box, so I ordered a set from Mike’s, but I am a little confused about how to stuff the module, because the PBC looks completely different than the one on the .gif
Was there a change in the design and the new one isn’t uploaded, yet?
you need a special variant of MIDIbox CV in order to get the module running (it’s currently only supported by a beta version of MIDIbox SID).
The gate will be available at the J5 port of the core module, which is normaly used for analog inputs…
I’m still working on the next MBCV release, e.g. a friend brought me his MS20 synth, so that I’m able to implement and especially to test the V/Hz output curve feature. Also a 96ppqn sync output is under construction. If nothing unexpected happens, I will release it this weekend.
You mentioned a beta release of the midiboxsid, does that mean, that I can controll a sid and an aout module with the same core? that would be really cool for me.
The firmware is final now, next step is to write the documentation for so many new options (ooof!)
yes, but the AOUT module is controlled by MIDIbox SID specific parameters, and there is no special menu which allows you to customize the function of each CV output. It can only be changed directly in the software.
