I have an additional Question about what John E.Finster asked in the first Post.
CORE (midi out) -----------> (midi in) MB_MF 1 (midi out) -------------> (midi in) MB_MF 2 (midi out) -----------------> (midi in) CORE
I connected my MF_NG Modules exactly like this. Core has ID0 the first MF_NG=ID1 and the second MF_NG=ID2
I configured it in .NGC like this:
MF n=1 enabled=1 midi_in_port=IN2 midi_out_port=OUT2 chn=1 ts_first_button_id=2001 config_port=USB2
on motorfader movements FaderCore
EVENT_MF id= 1 fwd_id=ENC:33 type=CC chn= 1 cc=32 range=0:127 lcd_pos=1:1:5 label=“^std_mf”
EVENT_MF id= 2 fwd_id=ENC:34 type=CC chn= 1 cc=33 range=0:127 lcd_pos=2:1:5 label=“^std_mf”
EVENT_MF id= 3 fwd_id=ENC:35 type=CC chn= 1 cc=34 range=0:127 lcd_pos=3:1:5 label=“^std_mf”
EVENT_MF id= 4 fwd_id=ENC:36 type=CC chn= 1 cc=35 range=0:127 lcd_pos=4:1:5 label=“^std_mf”
EVENT_MF id= 5 fwd_id=ENC:37 type=CC chn= 1 cc=36 range=0:127 lcd_pos=5:1:5 label=“^std_mf”
EVENT_MF id= 6 fwd_id=ENC:38 type=CC chn= 1 cc=37 range=0:127 lcd_pos=6:1:5 label=“^std_mf”
EVENT_MF id= 7 fwd_id=ENC:39 type=CC chn= 1 cc=38 range=0:127 lcd_pos=7:1:5 label=“^std_mf”
EVENT_MF id= 8 fwd_id=ENC:40 type=CC chn= 1 cc=39 range=0:127 lcd_pos=8:1:5 label=“^std_mf”
on touchsensor event FaderCore
EVENT_BUTTON id= 2001 type=NoteOn chn= 1 key=0x68 range=0:127 lcd_pos=1:1:7 label=“^std_btn”
EVENT_BUTTON id= 2002 type=NoteOn chn= 1 key=0x69 range=0:127 lcd_pos=2:1:7 label=“^std_btn”
EVENT_BUTTON id= 2003 type=NoteOn chn= 1 key=0x70 range=0:127 lcd_pos=3:1:7 label=“^std_btn”
EVENT_BUTTON id= 2004 type=NoteOn chn= 1 key=0x71 range=0:127 lcd_pos=4:1:7 label=“^std_btn”
EVENT_BUTTON id= 2005 type=NoteOn chn= 1 key=0x72 range=0:127 lcd_pos=5:1:7 label=“^std_btn”
EVENT_BUTTON id= 2006 type=NoteOn chn= 1 key=0x73 range=0:127 lcd_pos=6:1:7 label=“^std_btn”
EVENT_BUTTON id= 2007 type=NoteOn chn= 1 key=0x74 range=0:127 lcd_pos=7:1:7 label=“^std_btn”
EVENT_BUTTON id= 2008 type=NoteOn chn= 1 key=0x75 range=0:127 lcd_pos=8:1:7 label=“^std_btn”
MF n=2 enabled=1 midi_in_port=IN2 midi_out_port=OUT2 _ chn=2 _ ts_first_button_id=2009 config_port=USB2
on motorfader movements FaderSlave
EVENT_MF id= 9 fwd_id=ENC:41 type=CC chn= 2 cc=32 range=0:127 lcd_pos=1:1:6 label=“^std_mf”
EVENT_MF id= 10 fwd_id=ENC:42 type=CC chn= 2 cc=33 range=0:127 lcd_pos=2:1:6 label=“^std_mf”
EVENT_MF id= 11 fwd_id=ENC:43 type=CC chn= 2 cc=34 range=0:127 lcd_pos=3:1:6 label=“^std_mf”
EVENT_MF id= 12 fwd_id=ENC:44 type=CC chn= 2 cc=35 range=0:127 lcd_pos=4:1:6 label=“^std_mf”
EVENT_MF id= 13 fwd_id=ENC:45 type=CC chn= 2 cc=36 range=0:127 lcd_pos=5:1:6 label=“^std_mf”
EVENT_MF id= 14 fwd_id=ENC:46 type=CC chn= 2 cc=37 range=0:127 lcd_pos=6:1:6 label=“^std_mf”
EVENT_MF id= 15 fwd_id=ENC:47 type=CC chn= 2 cc=38 range=0:127 lcd_pos=7:1:6 label=“^std_mf”
EVENT_MF id= 16 fwd_id=ENC:48 type=CC chn= 2 cc=39 range=0:127 lcd_pos=8:1:6 label=“^std_mf”
on touchsensor event FaderSlave
EVENT_BUTTON id= 2009 type=NoteOn chn= 2 key=0x68 range=0:127 lcd_pos=1:1:8 label=“^std_btn”
EVENT_BUTTON id= 2010 type=NoteOn chn= 2 key=0x69 range=0:127 lcd_pos=2:1:8 label=“^std_btn”
EVENT_BUTTON id= 2011 type=NoteOn chn= 2 key=0x70 range=0:127 lcd_pos=3:1:8 label=“^std_btn”
EVENT_BUTTON id= 2012 type=NoteOn chn= 2 key=0x71 range=0:127 lcd_pos=4:1:8 label=“^std_btn”
EVENT_BUTTON id= 2013 type=NoteOn chn= 2 key=0x72 range=0:127 lcd_pos=5:1:8 label=“^std_btn”
EVENT_BUTTON id= 2014 type=NoteOn chn= 2 key=0x73 range=0:127 lcd_pos=6:1:8 label=“^std_btn”
EVENT_BUTTON id= 2015 type=NoteOn chn= 2 key=0x74 range=0:127 lcd_pos=7:1:8 label=“^std_btn”
EVENT_BUTTON id= 2016 type=NoteOn chn= 2 key=0x75 range=0:127 lcd_pos=8:1:8 label=“^std_btn”
Is this the correct configuration for 2 Modules?
The thing that makes me unsure is that if i change line “MF=n2” to ch=1 -it does nothing.
But if i delete the chn=2 of line “EVENT_MF id= 9” it receives Chn# 1 in the midi monitor of MIOS Studio on USB1 and ID0 = LPC17_Core
im trying to make it emulate Motormix. (don’t know if its necessary to know that :D just for sure… )
best regards
novski
