How to determine a SR /PIN of a button? (SOLVED)
Sorry, I sorted it, you just hook up to MIOS and press the button in question and the SR and PIN comes up in the bottom window…sorry to waste anyones time
----------------------original query-----------------------------------
I want to change a button that I cant find the SR / Pin numbers of… is there any simple way to find this out?
On the (premade ) panel the button is labelled as F3, however it ( and the other F number buttons DO NOT correspond to the F buttons in the HW file ( all are set to 0   0 ) , I have managed to find the others by pressing their functions ( save, save all , ? , undo ) then using the SR PIN numbers to redistribute these buttons to new functions …this has worked for all other F numbers, but pressing F3 doesn’t seem to DO anything, so I cant use this to diagnose the  numbers
if it helps the other SR PINS are
F1     9   3
F2     9   6
F3     ???
F4     10   4
any ideas?
Phill
