2 x MBHP_DINX4 (only 6 74HC165 shift registers used)
2 x MBHP_DOUTX4 (7 74HC595 shift registers used)
1 rotary encoder (for tempo, could also be used for additonal purposes in future)
33 buttons
35 LEDs (33 could be integrated into buttons, 2 additional LEDs to display selected layer and record mode)
And i don’t find how to connect buttons, encoder and LEDs to DINX, DOUTX modules. What of DINX channel belong to shift, alt, A,B,C,D buttons etc, and where is encoder must be connected ?
Also firmware for this variant is setup_808_default.hex or setup_808_tk.hex or ?
If you are building TK’s variant (which I think you are) then if you look in setup_808_mbseqv3_tk.asm (within the midibox_808_v1_1a.zip file) it tells you exactly how everything should be connected. Also http://www.ucapps.de/midibox_808.html tells you how the buttons should be layed-out.
