zero
1
If someone is looking for a pcb in eagle, i found a way cause i didn´t see in the site that image (black&white).
Open Eagle; File->open->board…
Open your brd fil; Change background: Option->User Interface->Layout->White
View -> Display/Hide Layers
Click None -> Select Bottom, Pads, Vias, Dimension(B,P,V,D)
Doubleclick on (B,P,V,D) and change the color to black.
File->Export: Image (duno the image dpi necessary but 300 seem to be good): Monochrome
It´s ready to be printed!
nILS
2
Maaan, I really thought you found a way to turn a .brd into a .sch there for a second
cimo
4
i had the same exact thought: this man s gonna change the world, doh!
zero
5
hey guys, i changed the title, sorry for confusing..
Other way using CAM processor:
Device = EPS
File = a name to save the file, with .eps extension
Select only this layers: Bottom, Pads, Vias, Dimension
Deactivate “Fill pads” check box
Click Process Job button to save it as a vector file, also ready to print (black and white,)and no worries about DPI.
You can also edit this file on Illustrator or other vector apps *hint* to change the board size, join boards, etc.*/hint*
cimo
7
If you print at home (i do cause no one here will print on PnP) then just hit the print button!!
If you use the export to image then you should use the maximum dpi specified in the printer but eps is waaay better and safer.
zero
8
Hey guys, almost finish my core module. I decided to take some photos like tutorial
http://picasaweb.google.com.br/trimpotzero/Core/
This is great info!! I am going to try it tonight!!
