How can i set/get parameters?
i’m trying to add some custom code to the NG app.
I want to set/get a parameter called kb_transpose. It seems that this parameter is part of MBNG_EVENT_CONTROLLER_KB event.
1.) Do i have to dispatch MBNG_EVENT_CONTROLLER_KB when i want to change the value of kb_transpose?
2.) How would i get the current value of kb_transpose?
As you can see i’ve trouble understanding how i can change parameters via code without using ngc/ngr scripts. I’ve no idea where parameters are stored and how i can access them. Is there a suitable tutorial for this?
Your help is greatly appreciated
Closer explanation:
I’m building a midi keyboard controller and would like to have two switches with respective indicator LEDs as octave up/down controls. The switches and LEDs are connected to J5a.
The 006_rtos_tasks tutorial should help me to understand where to put my custom code, right?
Hi.
i’d appreciate some help understanding how the NG app works.
I want to transpose (octave up/down) a keyboard, but don’t understand where the respective variable is stored and how i can change its value.
In MBNG_KB_NotifyToggle (mbng_kb.c) line 173 i found this:
s8 kb\_transpose = (s8)item.custom\_flags.KB.kb\_transpose;
This appears to be the place where the transpose value is added to the actual note pressed. Is this correct?
How can i change kb_transpose myself?
Thank you very much
It looks like kb_transpose is stored in mbng_event as
Quote
mbng_event_item_t
Where are the “event items” generated?
I think that this question is obsolete:
< base_url >/topic/21174-please-help-me-to-understand-how-the-ng-app-works-internally/?do=embed&embedComment=184813&embedDo=findComment#comment-184813
