When you put multiple 24LC512 (or 24LC256) on the same “chain”, pins 4-8 will be the same on both (like you have in this picture)… but E0/E1/E2 must be different, they give that IC it’s “ID”.
It’s simplified a bit… you would connect up the 5V and ground pins also… this means you can join many pins of one IC together and then just connect each IC to a common wire.
You can remove any of the ICs in this schematic… ie. you can have just two, one with ID=0 and one with ID=7 (for MB-SID this is good, ID=7 is used for the “ensemble” storage, ID=0 to ID=6 is for patches).
thank you wilba, this answer make it much clearer to me. i dont know how it works. but your explanation and the link to the pdf should be added to the bankstik page http://www.ucapps.de/mbhp_bankstick.html for newbies to understand better? the schematics on that page is alittle blury and tiny.
The schematic was already on the BankStick page as directly visible .gif file…
However, I added a link to the .pdf and Wilba’s explanation (slightly changed… Wilba: if you want to change the wording, just modify the file in the repository)
